Re: powerglide tranny in 3000lb car
[Re: fishy340]
#933593
02/21/11 01:27 AM
02/21/11 01:27 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
what do u guys think of powerglides in a 3000lb street/strip beast?
Well, that's an incredibly open ended question! When ordering a converter, the first thing they will want to know is exactly what you mean by Street/Strip... 80/20? 50/50? 20/80? Are you gonna be one of those guys that begs for a 5000 stall then calls them back 2 months later to complain about losing 2 MPG's?? Or ask for a 3800 and then complain when you lose a 10th in 60'??
Bad News, with a Street/strip Glide, converter choice is EVERYTHING! Good News, converter choice, and quality for a glide is much better than what is offered for a 904/727.
While I've ran Glides in my drag cars for 15 years and am extremely satisfied with that choice, I decided to stay with a low-gear set 904 in my Strip/Street 3000 lb 62 Valiant with 389 small-block. To be truthfull, the jury is still out, the griner pro-tree LBA brake, re-build, carbon fiber sheild, and new J&W Converter actually set me back more than I could have done a suitable glide for, then I trashed the D-shaft, so I have to build a new one, and I upgraded the shifter...so now I'm looking back thinking...this better work!!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#933594
02/21/11 01:54 AM
02/21/11 01:54 AM
Posts: 2,526 PA
moparacer
PA
Wouldn't have anything else in a car that I bracket race. I run one in a 3100Lb BB Dart.
A car that is going to see street use however I don't think I would go with a glide.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Dabee]
#933597
02/21/11 11:23 AM
02/21/11 11:23 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Just my opinion as everyone else is giving one but, I would like to include more than the weight of the car for making the better choice.
I would venture to say that most big blocks do not see huge improvements with a torqueflite. Small blocks with over 4" of stroke may not see much either. I am talking cars over 3,000 lbs. If your car is light your bannanas are not comparable with these potatoes.
You need to look at where your engine makes power. Narrow power bands will benefit from the gear ratio of a torqueflite. If your engine is torque limited in comparison to HP a powerglide is not going to be a good choice.
I have made no secret my nitrous combo really suffered in the short times with a glide after removing the 727 with stock gearing. But, the quarter mile picked up big time. Looking at acquisition prooved it was the limited holding power of the 9.5" torque converter that made the torqueflite slow on top. After big gear changes I found the short times with the glide. And everthing got JINGY. In hind site a high first gear, a tranny spacer, and a GM dept converter would have been even faster with the flite. So spend $2,000 extra on the torqueflite and it would have been faster than the Glide. I had about $2,500 in the torqueflite. $3,500 was spent just to build the glide. So a torqueflite for my combo would have been more expensive.
Most guys do not need aftermarket planets, in 727 no matter how heavy the car. Powerglides will break planets with tire shake. Never broke a planet when I ran a nitrous combo. With the NA engine torque is limited and tire shake happens.
Light bracket cars=powerglide best choice Narrow power band engines=torqueflite Limited torque high HP=torqueflite Big power/Big torque=powerglide
You just have to consider weight, power, torque, and anything else like power adders. I would have no reason to say a powerglide is not for the street. And if you run a 727 figure $500 for a drum that will not blow up. Don't care what sprag, output shaft, or planet you have. Do not race a 727 without a billet Drum. And then just give the one finger salute to the guys who talk about loosing feet. You will have nothing to worry about.
Leon
