512 "Street Motor" Dyno Results
#933532
02/20/11 10:11 PM
02/20/11 10:11 PM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
I built this low stressed motor for the street to run on pump gas and to be installed in my 67 Coronet. So be easy on me fellas, this is not a race motor; I just wanted a good 500 hp motor. It is a World cast iron block, 512 with 4.375" bore and 4.250" stroke, Diamond dish pistons with Indy EZ heads (75cc) ending up with a 10.2:1 cr. Scott Brown hyd cam int: 245@.050" ex: [Email]254@.050" with .565" lift. Johnsosn anti- pump up lifters and Indy 1.5:1 roller rockers. Indy dual plane topped off with a 850 Mighty Demon carb. Firecore coil and mechanical dist. (last pull was @ 36 degrees total) I want to thank Dave's Performance (QUICKD100) for helping me out and operating the dyno and doing a lot of adjustments/troubleshooting for me the last couple of days also to Maximus_Wedges and ANDYF. Saturday we installed the motor on the dyno and after having Some timing, fuel and Demon carb issues we finally fired it up and broke in the cam. This morning (Sunday) we pulled the plugs, changed and inspected the oil filter and inspected the rockers. After a couple of great pulls with an 850 Holley, Dave went back and setup the Demon with baseline air bleeds and richened up the primary side. We ended up with 600 ft lbs of torque@3200 rpm and peaked at 621 ft lbs@3666 rpm and stayed around 600 all the way to 4750 rpm and not dropping off much all the way to 5500 rpm(535 ft lbs). HP numbers were 562hp@5551 rpm. Needless to say, I was very pleased with the numbers. I will try and cut and paste the numbers tomorrow. This has got one flat torque curve and should be fun in my Coronet.
Re: 512 "Street Motor" Dyno Results
[Re: Hemi_Ram]
#933534
02/20/11 10:16 PM
02/20/11 10:16 PM
Posts: 2,091 Delray beach, Florida
Performance Only
that's a great street combo. you'll have a lot of fun with it. we've done dozens of similar combos like that for street use. i hope the rest of the drivetrain is up to the challenge of that torque. should also be very easy maintenance. ![](/ubbthreads/images/graemlins/thumbs.gif)
machine shop owner and engine builder
[Re: Streetwize]
#933540
02/20/11 11:20 PM
02/20/11 11:20 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
NIIICE job, buddy!
You'll have a lot of fun with all that torque.
Excellent choice of components, everything works together really well.
You probably have another 20+ up top with just a bigger carb, especially with that awesome indy Dual plane. My old (and very similar) 508 loved a pro-systems 1000hp.
The motor only was using [Email]756cfm@5900rpm.[/Email] I wasn't real happy with the BG carb, it was supposed to be tuned for this combo when Larry recieved it. The air bleeds were WAYYYY off right from BG. It was dead lean, I replaced the bleeds and installed sizes listed on their website. The carb still didn't want to run. I ended up completely disassembling and cleaning it. The primary block was screwed up from BG, looked like someone had missed the center drilling a hole and decided to try again. They ended up with a figure 8 on one side. We screwed around fighting carburation for a day. I'm quite sure we could have found some more power with more time on the dyno. We met and exceded Larry's goals for the motor though. Larry did a great job designing this little street terror. We did all the pulls on 110race gas as we initially got a bad batch of 91. Maximus Wedges, Kevin, was kind enough to run home 30 miles and bring some 110 race gas back to save the day. With the torque the motor makes Larry will be buying alot of rear tires this summer. Dave ![](/ubbthreads/images/graemlins/drive.gif)
[Re: Hemi_Ram]
#933548
02/21/11 12:36 PM
02/21/11 12:36 PM
Posts: 2,878 SE Nunya
Bubba
SE Nunya
Excellent Post... Just what I wanted to read. I will be attemting to do almost the same engine here in the future for my 70 Coronet. World Iron Block 4.395 Bore, Callies 4.250 Stroke Crank. Pump Gas is a must. Still undecided on the Heads and Cam. Hydraulic Roller or Small Solid since I have bushed lifter bores. What oiling system are you running on this? Transmission upgrades? Rear end? and if you could change anything (or things) what would it be? AndyF and Scotty Brown are both huge helps with these combos. Thanks for the post. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: ChrgrCuda]
#933553
02/21/11 02:40 PM
02/21/11 02:40 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
If I'm not mistaken that's the same (or very similar) spec cam that Paul (PHJ426 on Moparts) put in the 508 "face distorter" motor I sold to him that was in my Charger. He runs it with a sixpack and factory manifolds and it pulls really hard well into the 6000's. I had a 252/258 @.050 Scott Brown Hydraulic roller in it before that, it was an easy 615-ish horse motor and that to hear it idle the cam seemed very mild in it but it still 'wall to walled' the massive torque and horsepower even up and over 6300. You can go to a bigger cam but if the heads work well in the mid lifts particularly you don't really HAVE to HAVE a "Big" cam and you'll still make awesome power. at 10:1 usually if your heads are non MW you can also hit a trade off point with a larger cam to where you actually give up more through the middle in torque than you gain in top end power....the only time this makes sense (e.t. wise) is if you have a nose heavy A body that just can't hook/use the big fat middle anyway. I always have a target hp/tq in mind when I build a stroker and for the street I usually go to the smallest cam that will safely get me there, figuring nobody ever complains about a street motor having great low end roll-on drivability and manners in traffic, so long as it still delivers like a Sledgehammer when you nail it. The best 500 motors for street duty I think have this kind of Jeckyl and Hyde personality, just add some right foot and all (you know what) breaks loose!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RodStRace]
#933555
02/21/11 02:54 PM
02/21/11 02:54 PM
Streetwize
Weddington, N.C.
Quick, I hear you on the peak CFM...but I've found on many many strokers that so long as a 500 incher will take WOT without bogging the reduced pressure drop though the middle will add some torque and also (kind of by default) give the top end charge a better run on the HP/acceleration curve. Also that big indy dual plane has at least aonther 15-20 more HP (even at standard port size) by just doing some radius work on the plenum-to-runner transitions...particularly in the lower half. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Streetwize]
#933558
02/21/11 08:06 PM
02/21/11 08:06 PM
quickd100
nielsville, minn.
Quick,
I agree with everything you said Bobby but for what Larry has in mind for the motor he's got more than enough. As a new dyno owner I'm also still a babe in the woods. There are so many features with this software that I don't understand yet and probably 98% of it I won't ever use. I still have a few hiccups do deal with too. My oxygen sensor decided it had had enough so I'll need to order one of those soon. One thing I do know for certain though, is the smarter I get the dumber I realize I am. Dave
