Re: truck magnum into a-body-oil pan gaskets
[Re: Andrewh]
#933203
02/20/11 08:15 PM
02/20/11 08:15 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I think if you install a LA crank in a Magnum, you will need to have the engine re-balanced. The Magnum pistons and rods are lighter weight than the LA versions.
You can use the one piece Magnum oil pan gasket if you make a wood or aluminum shims to glue in and fill the gaps at the top. Or hammer them out of the pan as said above.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: tt76400]
#933207
02/21/11 08:20 AM
02/21/11 08:20 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I'm running an LA 4" crank in my 98' 5.9 block. I did have to rebalance it. It has the LA timing cover and oil pan using the magnum rear seal and LA oil pan gasket. The magnum gasket was gushing oil at the inside corners as said above.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: StrkrDart69]
#933209
02/21/11 10:18 AM
02/21/11 10:18 AM
Posts: 2,325 Löffingen, Germany
The_Mean_Machine
Löffingen, Germany
I use a 360 LA pan with LA timing cover and use the magnum 1 piece pan gasket with no shims and no problems. 69 Dart
was that on a Magnum 360 or 318. I can not believe that 318 Magnums use the 360 pan...
