Page 2 of 3 1 2 3
Re: Whats the deal with Engine diapers next year? [Re: biginchmotor] #933035
02/20/11 07:56 PM
02/20/11 07:56 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'ld love to see them to.
If you don't have any you could drag the car out here and I'll be happy to take and post some
Re: Whats the deal with Engine diapers next year? [Re: WILD BILL] #933036
02/20/11 08:02 PM
02/20/11 08:02 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I don't.....I'm sorry!
Re: Whats the deal with Engine diapers next year? [Re: ] #933037
02/20/11 08:30 PM
02/20/11 08:30 PM
Renton Washington
Triple Threat Offline
Renton Washington
Why don't the tracks do a novel approach like:
$50 entry and you get a 10% discount with an oil retention device installed.
Hate to kick a guy while he's down but I think it makes more sense to charge a $50 entry and charge a penalty for an oil downs.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Whats the deal with Engine diapers next year? [Re: PUNK] #933038
02/20/11 09:10 PM
02/20/11 09:10 PM
OHIO
THE GLASS MAN Offline
OHIO
We went through tech last week and were told that next year all 10.99 or faster cars will be mandated to have the engine diapers. Do these all have to be custom made for the application? Is there companies that make them ready to go for our rear stear Chryslers? Do they have to be SFI approved? I noticed a company called DRE engine diapers and they make them custom. Im just not sure what the costs would be. How many of you guys are currently running an engine diaper on your ride?
I am sure that a big engine diaper company will be heavily sponsoring the NHRA next year at our expence. What do you guys think?
Re: Whats the deal with Engine diapers next year? [Re: THE GLASS MAN] #933039
02/20/11 09:13 PM
02/20/11 09:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I don't think so.....this rule has started at smaller tracks like Milan
Re: Whats the deal with Engine diapers next year? [Re: THE GLASS MAN] #933040
02/20/11 09:16 PM
02/20/11 09:16 PM
Lehigh Acres, Florida
rickstershemi Offline
Just ask all the drivers that have run over their internals at the stripe what they think
IMO it's probably one of the top 10 smartest rules
Rickster
Re: Whats the deal with Engine diapers next year? [Re: WILD BILL] #933041
02/20/11 11:13 PM
02/20/11 11:13 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
That's good to hear Josh. WHo did yours and is it custom fit?
I think the only other concern I have is at least 1 header tube the comes close enough to the block that I'ld be worried about it touching the diaper.
DRE made mine and there are two tubes that touch the diaper. He sewed Kevlar patches where the tubes touch and they protected the diaper real well. He didn't put one of the patches in the right spot and it burned one of the straps, but he fixed it for free. This is a full length Ray Barton pan, kickout, drag link tube, sight glass, external oil lines.
The straps are a real pain, especially the rear two. The front straps attach to brackets on the front header bolts, the rear are positioned between 5&7 and 6&8 so going to either header bolt interferes with the plugs. I drilled and tapped the header flange between the two cylinders for a stud that the bracket mounts to.
Re: Whats the deal with Engine diapers next year? [Re: THE GLASS MAN] #933042
02/21/11 03:58 AM
02/21/11 03:58 AM
OHIO
OHIO
What is the going price for a diaper on a big block a-body? Or how many fiberglass Hemi scoops do I have to sell.
Re: Whats the deal with Engine diapers next year? [Re: THE GLASS MAN] #933043
02/21/11 09:09 AM
02/21/11 09:09 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
there is a pic floating around here somewhere of bigtimes fabbed belly pan....
Mopar Performance
Re: Whats the deal with Engine diapers next year? [Re: moparniac] #933044
02/21/11 09:22 AM
02/21/11 09:22 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
bigtimes and bondos (pics in heads up thread)
Mopar Performance
Re: Whats the deal with Engine diapers next year? [Re: J_BODY] #933045
02/21/11 10:34 AM
02/21/11 10:34 AM
NC
440Jim Offline
440Jim  Offline
NC
http://www.russlerii.com/ ....and besides if you have any issues he's just a drive across the mohave for you. Been a few members here that have had blankets made by him.
Sounds good, and $158 is priced OK.
But it looks like those hugh metal ends will have problems fitting on a header flange? On mine (2-1/8), you have to used reduced head bolts (3/8 thread, 5/16 hex) and you can't fit a washer on there never-the-less that metal strap end???
Does anyone have a close up picture of how that goes on the header bolt/flange?
And how about a sewn cut-out for the engine mount to frame connection? I use a front motor plate, but the passenger side engine mount is used as a fore-aft travel limiter/brace.
Re: Whats the deal with Engine diapers next year? [Re: 440Jim] #933046
02/21/11 10:47 AM
02/21/11 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds good, and #158 is priced OK.
But it looks like those hughe metal ends will have problems fitting on a header flange? On mine (2-1/8), you have to used reduced head bolts (3/8 thread, 5/16 hex) and you can't fit a washer on there never-the-less that metal strap end???
You might want to weld the metal ends right on the
header flange... just a thought
Re: Whats the deal with Engine diapers next year? [Re: Dads426] #933047
02/21/11 10:55 AM
02/21/11 10:55 AM
NC
440Jim Offline
440Jim  Offline
NC
DRE made mine ...
That stud is a good idea.... for headers with a full flange, mine are cut separate with nothing between them. Something can be fabricated, but it takes money.
Re: Whats the deal with Engine diapers next year? [Re: MR_P_BODY] #933048
02/21/11 11:16 AM
02/21/11 11:16 AM
NC
440Jim Offline
440Jim  Offline
NC
Like I said, it can be fabricated. It just takes more money. By the time you hire a welder, fabricate new brackets, etc. it doubles the cost of the diaper. At least my engine is out of the car for the winter, so it will be easier to measure, modify, etc.
Re: Whats the deal with Engine diapers next year? [Re: 440Jim] #933049
02/21/11 11:17 AM
02/21/11 11:17 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
does anyone have what tech says to what needs to be covered! I cant see getting one of those diapers on a proparts style header especially on dr side!...
Mopar Performance
Re: Whats the deal with Engine diapers next year? [Re: MR_P_BODY] #933050
02/21/11 11:20 AM
02/21/11 11:20 AM
ky
68roadrunner Offline
ky
i have a oil pan heater on the bottom, wonder how that will work out?
Re: Whats the deal with Engine diapers next year? [Re: 68roadrunner] #933051
02/21/11 12:07 PM
02/21/11 12:07 PM
ill
dennismopar73 Offline
ill
i dono but i checked out ruslier site this is what he says
THE ONLY DIAPER YOU WILL NEED THIS YEAR!
does this mean next year you have to buy one that cert
by nhra,,
Re: Whats the deal with Engine diapers next year? [Re: dennismopar73] #933052
02/21/11 03:22 PM
02/21/11 03:22 PM
Central Missouri Fort Leonard...
mopar65 Online happy
mopar65  Online Happy
ok i have a few questions. what about us that also plan on driving our cars on the street. i mean will it cause my car to over heat in the summer? looks like it would act like a heating blanket? also does it come with a hole to change your oil? i only plan on running no more than 10.00-10.30 in the 1/4 so dont know if this applays to me? sorry for the dumb questions. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Whats the deal with Engine diapers next year? [Re: mopar65] #933053
02/21/11 03:40 PM
02/21/11 03:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not dumb questions at all, IMO, since I'm in the same situation.
Am I to interpret this thread that my 10-sec. street-driven car needs a freakin' diaper when it returns to an NHRA track this year? Or am I going to have be a a "One Track Pony" and stick to IRHA-only events?
Re: Whats the deal with Engine diapers next year? [Re: BradH] #933054
02/21/11 03:50 PM
02/21/11 03:50 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I did not have an issue with temp in my car that was caused by the diaper.
My blanket was designed to have a spot to change the oil in it from Russel, i just had to show him where to put it.
Page 2 of 3 1 2 3
