Holley 2300 Series 440-6 Rebuild Kits?
#93272
07/22/08 11:37 PM
07/22/08 11:37 PM
Posts: 114 USA
stan1970
USA
Hello, I'm trying to track down a rebuild kit for my Holley 440 Six-Pack setup. As I understand it, these are 2300 Series Carbs. I am seeing different types of Rebuild Kits at different online sites. Holley seems to offer a "Fast" and a "Renew" kit. Any idea which one I should be looking for? Also, on Mancini's site - the Six-Pack kit is listed as # 3-396. But on Summit, it shows that part# as a Marine Carb ? At Summit, it looks like it's a 3-397 .... Uggh! I'm confused! Has anyone bought a 440-6 rebuild kit lately and could provide the correct part # and/or web site link to the one that worked for them? And are these the same part # for center and outboard carbs? So, I would just need to purchase 3 kits, right? Also, do these kits contain the Carb-to-Manifold mounting Gasket? If not, is that one special for the Six-Pack or do I just buy 3 standard Holley 2-bbl gaskets? Thanks a lot as usual!!!!
Re: Holley 2300 Series 440-6 Rebuild Kits?
[Re: stan1970]
#93273
07/22/08 11:44 PM
07/22/08 11:44 PM
Posts: 704 USA
rftroy
USA
The correct part number is 3-396. Try googling "Holley 3-396" and look around for the lowest price. I can't remember where I got my last set (you need one kit for each of the three carbs, by the way. The kit isn't for the whole six pack) but you will probably find the best prices on Jegs or some other big scale retailer.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: stan1970]
#93275
07/23/08 12:17 PM
07/23/08 12:17 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
Does anyone know if the carb-to-manifold mounting gasket is included in the kit? Also, whether both outboard and center carbs use the same mounting gasket?
In the Holley renew kit, it does come with the gaskets and they are the same. You might try calling www.promaxcarbs.com/ They sell everything for sixpacks.
[Re: stan1970]
#93281
07/23/08 11:03 PM
07/23/08 11:03 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Depending on your experience and what you want to do with these carbs, you may want to consider shipping them to Promax or Harms. The cost difference may be worth it to you in the long run, as there are some issues that one needs to be aware of when rebuilding and tuning them. They are both experts.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#93282
07/23/08 11:22 PM
07/23/08 11:22 PM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
just bought mine from mancinni. came in new holley boxes, but different gaskets in 2 boxes.P O me!!
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: stan1970]
#93284
07/24/08 01:53 AM
07/24/08 01:53 AM
jbc426
West Coast, USA
I had Promax go through mine and do some additional modifications. Then they run them on a test motor to tune them in. Just explain your set-up to them, and they will give you some options. I think Ben is the guy I worked with. Mine came out great. I credit some of their modifications for helping my motor churn out 682 hp at 5500 rpm. Good stuff at Promax!!!
