Re: 440 Source distributor
[Re: fourgearsavoy]
#932469
02/20/11 04:24 PM
02/20/11 04:24 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Does the 440source distributor use a stock cap?
No. Uses the GM HEI style..
Just my $0.02..
WRONG! It uses a MOPAR magnum style cap with male or female terminals available with a clip style retainers ![](/ubbthreads/images/graemlins/Twocents.gif) Gus
My reference was to the type of connector used.. The standard Pro-Comp distributor uses a male type connector similar to a spark plug tip... 440Source sells the Pro-Comp but has (2) versions of caps available, 1 is the male type connector and the other is the standard female type as used in the Mopar OE stock caps.. The choice is yours.. Funny how the most simple things can get twisted around..
![](/ubbthreads/images/graemlins/eeek.gif)
Just my $0.02.... ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Sinitro]
#932470
02/22/11 12:30 AM
02/22/11 12:30 AM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
Thanks for the replies. Has anyone had any issues with performance or longevity? I will be using some factory heads for my build. Anyhow I appreciate your input, Thanks.
Better get inside Ma. Looks like a storm's comin'.
[Re: Dartthunder340]
#932471
02/22/11 01:21 AM
02/22/11 01:21 AM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The distributor costs $100. - what do you expect for that money ?!?!?
[Re: farmboy]
#932473
02/22/11 08:36 AM
02/22/11 08:36 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Why to buy expensive MSD? You can get well workeing and curved distributor for smaller price. Take call to Don Gould from FBO Systems. I ordered from Don all kind of distributros through years and had zero problems! http://4secondsflat.com/Ignition.html
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
[Re: Sinitro]
#932475
02/22/11 01:58 PM
02/22/11 01:58 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Just my $0.02..
Just my $0.02....
My point is that I think only the procomp caps fit....why didn't they make it so an actualeasy to get parts store magnum or stock cap would fit? I have a gutted pro-comp I am using for a prototype for something (I welded the advance solid) and I didn't realize that it didn't use a commonly available cap when I got it.
