Re: What causes thrust on the crank to go?
[Re: TheOtherDodge]
#932335
02/19/11 03:39 PM
02/19/11 03:39 PM
not enough clearance on the converter to the flexplate or if your converter bolts came loose a few times causing the converter to bang the flexplate shocking the crankshaft.
#932336
02/19/11 04:19 PM
02/19/11 04:19 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
staying on the converter or trans brake too long
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#932337
02/19/11 06:23 PM
02/19/11 06:23 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Ding, Ding, Ding...winner winner, chicken dinner..lol.......Fluid pressure, is trying to blow the converter out of the front of EVERY trans. Does not matter if the converter is ballooning or not, it IS pushing on the crank. Turbo combos are notoriously hard on thrust surfaces.
Monte
[Re: Monte_Smith]
#932339
02/19/11 06:38 PM
02/19/11 06:38 PM
Monte
There's more than 1 reason for thrust bearings to go south. Yes thats one of them but you need to look at different avenues to cause the problem.
[Re: HEMIFRED]
#932340
02/19/11 06:45 PM
02/19/11 06:45 PM
Posts: 1,200 UK
602heavy
UK
This is the reason i chamfer parting line of thrust bearing , puts pressurised oil to rear thrust face , might not help in all cases but it helps.
[Re: TheOtherDodge]
#932342
02/19/11 07:32 PM
02/19/11 07:32 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
crank flex,,,, by heavy bob weights or too much power for the material of the crank...
what clearance did you run? you may want to open it up .005 or more,, usual is .004-.010 but ihra type pro stock motors have to run .025 or more because of flex
you may need to be at .015,, id try to open it up .005-.007
[Re: TheOtherDodge]
#932344
02/19/11 07:53 PM
02/19/11 07:53 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I was discussing this with a friend..
Let's say I had "x" amount (doesnt matter what it is). If nothing was wrong with converter, etc, even if it is too small, wouldn't the thrust "naturally seat itself"? NO! How would this cause it to totally kill all the thrust? Restricted oiling to the thrust bearing. Are both bearing halves worn evenly?
[Re: goldmember]
#932345
02/19/11 08:40 PM
02/19/11 08:40 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
what did the journal side of the bearing look like? that will tell you if the problem is from something else besides the converter / TB pressure.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: HEMIFRED]
#932348
02/20/11 12:04 AM
02/20/11 12:04 AM
Posts: 446 oregon
savoyracer
oregon
... ....i am dealing with this very same issue right now. What amount of time would you consider staying on the convertor, or brake to be to long?
[Re: pittsburghracer]
#932349
02/20/11 12:06 AM
02/20/11 12:06 AM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Under the don't ask me how I know engine build my engine builder (me)forgot to check the converter to crankshaft hub clearance the first time I used a K1 crank. Instead if having clearance to float in the hub it thrusted the crank forward taking out the thrust. When I discussed this with another local Mopar builder he had this happen to him with an Eagle crank. Make sure it float in the hub.
I've seen this happen on a Hemi.
Kevin
[Re: ccdave]
#932350
02/20/11 12:09 AM
02/20/11 12:09 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I know a guy who bought a Valve body used. Turns out some holes in the seperator plate (powerglide) were blocked off. His line pressure was extreme and ruined two cranks before he realized what was causing it. Check the line pressure of the transmission.
[Re: savoyracer]
#932351
02/20/11 12:49 AM
02/20/11 12:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think bigger torque would build heat easier so the question might be somewhat hard to answer... but on my SB I can stand right on the converter from the top bulb to the last and it hasnt hurt the engine or trans in 5 +years... I run right up on the stall... 5600
