5.9 cummins swap into car #930333
02/16/11 01:31 PM
02/16/11 01:31 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
has anybody swapped a cummins 5.9 engine in a car chassis?
Re: 5.9 cummins swap into car [Re: bucket] #930334
02/16/11 01:36 PM
02/16/11 01:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There's the 70-72 monte carlo on the tube.
Re: 5.9 cummins swap into car [Re: bucket] #930335
02/16/11 01:37 PM
02/16/11 01:37 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I can not imagine that happening ... the motor is tooo big and toooo heavy.
Re: 5.9 cummins swap into car [Re: buildanother] #930336
02/16/11 01:42 PM
02/16/11 01:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I told Feets to put one into his new Sea body too.
Re: 5.9 cummins swap into car [Re: bucket] #930337
02/16/11 01:56 PM
02/16/11 01:56 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
The cummins is an awesome motor, but it is way too big and heavy for a car. Yes, it's been done but there is no good reason unless it's just for the novelty. A person would be way better off using a PSD or Duramax as they are far more compact and lighter. The front suspension of my 1 ton trucks isn't really up to the weight of a Cummins ISB.
Funny, people here often espouse the virtue of a small block over a big block for handling....can you imagine the handling using a motor that is 400 - 500 lbs heavier (and without all the aftermarket aluminum goodies available to make it any lighter)?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 5.9 cummins swap into car [Re: bucket] #930338
02/16/11 02:12 PM
02/16/11 02:12 PM
Springfield, MO
Steve88 Offline
Steve88  Offline
Springfield, MO
The 5.9 is huge but a Cummins 4BT would fit nicely. A 4BT is a quite a bit smaller and lighter but still extremely durable. They were commonly used in medium duty trucks like bread trucks. I have considered swapping one into my 72 Satellite.
Re: 5.9 cummins swap into car [Re: Steve88] #930339
02/16/11 03:05 PM
02/16/11 03:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There's one guy on here who swapped a 4bt cummins into his mopar wagon. A 4cyl cummins is supposed to weigh about what a big block weighs. A 6cyl cummins, well, much, much more.
Re: 5.9 cummins swap into car [Re: DaytonaTurbo] #930340
02/16/11 03:25 PM
02/16/11 03:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Shipping weight on a 6BT is 1200 lbs. That's like having two small blocks under the hood.
Try this: http://www.4btswaps.com/forum/index.php
- Stu Harmon
Re: 5.9 cummins swap into car [Re: bucket] #930341
02/16/11 07:18 PM
02/16/11 07:18 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yes it has been done .
saw a early nova with a stock 12v in at cicel co dragway last year .
mid 11 sec .
Re: 5.9 cummins swap into car [Re: calrobb2000] #930342
02/16/11 07:25 PM
02/16/11 07:25 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
mid 11 sec .
Stock 12V and goes 11s? Ive gotta raise the flag on that....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 5.9 cummins swap into car [Re: Von] #930343
02/16/11 08:47 PM
02/16/11 08:47 PM
DPelletier Offline
DPelletier  Offline
mid 11 sec .
Huge potential with minimal mods BUT the highest stock hp for a 12V was 215hp....not that anyone drag racing one would leave it bone stock. Probably meant stock engine internals, which is quite possible.
Re: 5.9 cummins swap into car [Re: bucket] #930344
02/16/11 11:12 PM
02/16/11 11:12 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
What a terrific idea. I think it would be great in a 69 Charger, then paint it orange and paint an 01 on the roof.
Sheldon
Re: 5.9 cummins swap into car [Re: RUNCHARGER] #930345
02/17/11 01:19 AM
02/17/11 01:19 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I had a 71-72 chrysler 300 that had a 400 in it was total fuel hog. Badly wanted a 12 valve for it, with correct gearing I would bet high 12s and 30 mpg. With the stock fuel tank I would think 800+ mile fill ups would be doable.
Re: 5.9 cummins swap into car [Re: bucket] #930346
02/17/11 01:29 AM
02/17/11 01:29 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A local guy runs one in his Imperial demolition derby car.
Re: 5.9 cummins swap into car [Re: DoctorDiff] #930347
02/17/11 08:25 PM
02/17/11 08:25 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
had idea to put one into a 33 plymouth coupe with a corvette IRS.
Re: 5.9 cummins swap into car [Re: feets] #930348
02/17/11 09:03 PM
02/17/11 09:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
But with the torque of four small blocks.
Don't be the exception.
Re: 5.9 cummins swap into car [Re: Supercuda] #930349
07/25/11 06:15 PM
07/25/11 06:15 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
is there such thing as a center stump oil pan for cummins?
Re: 5.9 cummins swap into car [Re: bucket] #930350
07/25/11 07:25 PM
07/25/11 07:25 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Here's a 4bt in a '74 Satellite Sebring.....it was posted in the project section last year.
4bt turbo in '74 Satellite
John
Re: 5.9 cummins swap into car [Re: bucket] #930351
07/25/11 07:57 PM
07/25/11 07:57 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
back in 08 was at the local Mopar show when I spotted this. 48-49? Merc. Why is this sled at a Mopar show????
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 5.9 cummins swap into car [Re: moparmarks] #930352
07/25/11 08:01 PM
07/25/11 08:01 PM
moparmarks Offline
moparmarks  Offline
CDL was why.
Didn't have room for the inner cooler. MPG was in the high 20's and made mountains seem flat.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
