Re: fixin' up old heads
[Re: Monte_Smith]
#929179
02/15/11 09:11 AM
02/15/11 09:11 AM
moparpollack
Lil Herman
Lil Herman
85086
Mr. Porter should post the amount of time he has in those, as well as the final tally on the bill, to reinforce the fact, that unless you are doing a resto type deal, aftermarket heads, are just better, as well as cheaper in the long run.
Monte
X2
[Re: Monte_Smith]
#929180
02/15/11 10:21 AM
02/15/11 10:21 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree 100% as does Dwayne I am sure. I am pretty sure he will be posting more info on this topic. I know the job he is showing,as he and I have spoke of it, and yes, the guy wanted the original J heads.Is it " cost effective" for an old J or X head anymore. I think not. You'll see why later.Also,Dwayne will be carving up a set of old J heads I have and we are going to see what happens at that point with cost, practicality and performance. I think his results will be interesting on that one. Dwayne and I were working on some small joint projects which dealt with just this situation. Is it WORTH fixing old heads anymore? I will let him answer, but I think it will become very obvious when he starts posting some more information. I wanted to see where practicality and performance starts and stops whith a typical street driven small block performance engine. Its pretty interesting once you dig deep into it. Anyhow, this is Dwaynes post, so we'll let him do his thing. BTW. I have been involved in and around drag racing all my life, in many different venues, ownerships, partners, cars, race tracks etc. I consider Dwayne a very good personal friend, and a business " partner", as we do a fair share together. I can tell you this, He is one of the most straight up, professional and talented cylinder head/engine guys you will ever meet. You get what you pay for, and Dwaynes work is some of the best out there. I highly recommend him. . Dont call him if you dont want to hear the truth, or the right way to do things. If you want to cut corners, he's not your guy. If you want it done right, then you'll be in good hands. ( since this was unsolicited, I sure hope I didnt make him blush... )
RIP Monte Smith
[Re: CompWedgeEngines]
#929181
02/15/11 11:40 AM
02/15/11 11:40 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Speaking as a vastly underqualified person of this forum........ and an owner of several sets of X & J heads. This is a great thread! As I read the threads on the "Can I use my aftermarket heads OOTB?", I've got to believe that getting those mass produced latest offerings up to race standards is NOT for free. Touching up the valve job, correct application valve springs & retainers, correcting valve guide tolerances, fixing exhaust valve seat inserts and whatever other horror stories........... Without going into what it costs for me to get a set here locally freshened.....I'm just wondering how much, on average, most racers pay IN TOTAL for a set of ready-to-run aftermarket heads. I know when it comes to "Quench" and using a better port & combustion chamber design it's worth the $$$. I understand if you want to go real fast..........then you start with a "clean sheet" engine build....open wallet wide if you want the big HP. It just seems like there may be a valid case where a budget minded bracket racer street/strip guy could justify using the old iron.
[Re: Dean_Kuzluzski]
#929182
02/15/11 11:47 AM
02/15/11 11:47 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Great thread and goes to show why some of these "rebuilt" engines run so poorly. I'm just glad to see Dwayne back posting some good stuff. BTW Dwayne, I'll be calling you soon for a cam for my '71 340 Demon.
#929183
02/15/11 01:05 PM
02/15/11 01:05 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Even if you did buy the new heads and they needed the valve job touched up, or maybe better springs, or maybe a little bowl blending.............in the end, they will still usually cost less than bringing a "used up" set of J heads back to life. Now you can short cut anything and save dollars, but I am talking about doing it right. Just like the pics posted. Many would have hammered new guides in there, ground the seats, put new valves in and called it a day..... although fresh, the heads still would have been junk. Doing it "right" and doing it "cheap" can never be one in the same.
Monte
[Re: Monte_Smith]
#929184
02/15/11 03:12 PM
02/15/11 03:12 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks Dwayne for the post as I also enjoy reading about some of the older stuff and making it better. There is a real good post (24 pages) on the flow bench forum were a member played with a small block mopar head. If anyone is interested here's the link. http://www.flowbenchtech.com/forum/viewtopic.php?f=25&t=54
[Re: Labratt]
#929187
02/15/11 05:33 PM
02/15/11 05:33 PM
Posts: 2,129 Vermont
TrWaters
Vermont
This is a very good post, and exactly the type of thing early hemi guys go through all the time.... fixin' up old heads.
TR Waters
[Re: TonyS451]
#929189
02/15/11 06:15 PM
02/15/11 06:15 PM
Posts: 7,506 Az
Crizila
Az
Quality work is easy to spot - chamfered bolt holes on resurfaced heads. Minor port work is done right where the pay-offs are biggest. Thanks for the post.
Fastest 300
[Re: Crizila]
#929190
02/15/11 07:49 PM
02/15/11 07:49 PM
Posts: 6,142 Melbourne , Australia
LA360
Great to see you back on here Dwayne, I have missed your posts! Seeing this really makes me wonder why I am bothering with the factory heads I have. The deal I had done to get them machined for free fell through, so I may as well put my money into NEW heads that will last longer!
You have mail to Dwayne! Thanks
Alan Jones
[Re: LA360]
#929191
02/15/11 08:05 PM
02/15/11 08:05 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Thanks Dwayne. Your posts hve been missed!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
#929194
02/15/11 09:55 PM
02/15/11 09:55 PM
LA360
The 360 heads I have required or still require: hot tanking sand blasting A full set of guide inserts exhaust seat inserts Machine for teflon guide seals enlarge the spring seats hone the guides cut the seats Machine out/extract broken exhaust manifold studs re-machine worn corroded exhaust gasket face Re-surface head
add in the cost of the core What does it equal to? I probably could have a RHS head machined up for the same $$$ or less, even if it's a little more, I end up with a better cylinder head!
Alan Jones
