Re: 440-1 head user what roller lifters
[Re: moparniac]
#928214
02/26/11 10:55 AM
02/26/11 10:55 AM
Posts: 16,932 NC
440Jim
NC
if it matters I forgot to mention the oil hole in mine is parralel with the lifter galley and the hole in the lifter is at 2.5" on the ruler pic right above the cutaway
Yes, Brian mentioned that to me before, to avoid excess oil flow, not direct to oil galley opening. Which doesn't matter if the block is bushed.
This old pic from Brian must have been a prototype, because yours looks like it has a taller section above the cutout?
[Re: supercomp]
#928216
02/26/11 12:16 PM
02/26/11 12:16 PM
Posts: 16,932 NC
440Jim
NC
Our low deck with B1's didn't hit the block with offset lifters. ![](/ubbthreads/images/graemlins/shruggy.gif)
Allen, Did your factory low deck block have these casting bumps under the intake ports? I can't see behind the pushrods in your picture? It could just be close due to manufacturing tolerances. ![](https://board.moparts.org/ubbthreads/upload2/6478732-Block_grind_offset_lifter6_57k.jpg)
[Re: supercomp]
#928218
02/26/11 03:10 PM
02/26/11 03:10 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
My low deck (400) Indy Maxx with offset lifters required block clearance. There was also a problem with the FelPro 1039 gasket interfering with the pushrod.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR]
#928219
02/26/11 03:19 PM
02/26/11 03:19 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I use standard roller lifters on my low deck with -1 heads and a 706/661 lift roller, Harland 1.5 rockers.
