Re: 440-1 head user what roller lifters [Re: 440Jim] #928213
02/26/11 10:51 AM
02/26/11 10:51 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
if it matters I forgot to mention the oil hole in mine is parralel with the lifter galley and the hole in the lifter is at 2.5" on the ruler pic right above the cutaway
Mopar Performance
Re: 440-1 head user what roller lifters [Re: moparniac] #928214
02/26/11 10:55 AM
02/26/11 10:55 AM
NC
440Jim Offline
440Jim  Offline
NC
Yes, Brian mentioned that to me before, to avoid excess oil flow, not direct to oil galley opening. Which doesn't matter if the block is bushed.
This old pic from Brian must have been a prototype, because yours looks like it has a taller section above the cutout?
Re: 440-1 head user what roller lifters [Re: moparniac] #928215
02/26/11 10:59 AM
02/26/11 10:59 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Our low deck with B1's didn't hit the block with offset lifters.
Re: 440-1 head user what roller lifters [Re: supercomp] #928216
02/26/11 12:16 PM
02/26/11 12:16 PM
NC
440Jim Offline
440Jim  Offline
NC
Allen,
Did your factory low deck block have these casting bumps under the intake ports? I can't see behind the pushrods in your picture?
It could just be close due to manufacturing tolerances.
Re: 440-1 head user what roller lifters [Re: 440Jim] #928217
02/26/11 02:59 PM
02/26/11 02:59 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
No actually they are just rounded all the way down. Wonder why.
Re: 440-1 head user what roller lifters [Re: supercomp] #928218
02/26/11 03:10 PM
02/26/11 03:10 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
My low deck (400) Indy Maxx with offset lifters required block clearance. There was also a problem with the FelPro 1039 gasket interfering with the pushrod.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: 440-1 head user what roller lifters [Re: MRMOPAR] #928219
02/26/11 03:19 PM
02/26/11 03:19 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use standard roller lifters on my low deck with -1 heads and a 706/661 lift roller, Harland 1.5 rockers.
