Shaker studs #927267
02/12/11 09:53 PM
02/12/11 09:53 PM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
Who is repairing broken studs on shaker trim rings ?
Re: Shaker studs [Re: FY1TA] #927268
02/12/11 11:22 PM
02/12/11 11:22 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Contact member mccannix - he had a source that would do them as original using a zinc rod.
Re: Shaker studs [Re: YYZ] #927269
02/13/11 12:13 PM
02/13/11 12:13 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Had a few bad on a a shaker challenger years ago. I ground them flush, put ring on hood and marked center of the hole of studs I needed to repair. Drilled and tapped through the entire ring, ran a machine bolt down through the top so it had a correct finished end the nut would go over. I remember setting them with jb weld and then grinding them down flush on top, needed very little spot putty to finish off on top.
Re: Shaker studs [Re: N9671X2] #927270
02/13/11 06:25 PM
02/13/11 06:25 PM
texas
magnum440 Offline
magnum440  Offline
texas
thats pretty much what i did except i used red loctite and used allmetal on top first after grinding top,then small amount of putty...was fairly easy...
Re: Shaker studs [Re: magnum440] #927271
02/13/11 06:50 PM
02/13/11 06:50 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
depends on how many are broken off, I just left my 2 alone..
