pipemax #925867
02/10/11 10:39 PM
02/10/11 10:39 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
can anyone decipher this pipemax page? i'm not quite understanding the collector length. are they giving the length from the header tubes or are they talking about the length of the bolt on collector?
Re: pipemax [Re: mopar dave] #925868
02/10/11 10:42 PM
02/10/11 10:42 PM
Mt Morris Michigan
Mt Morris Michigan
here's another.
Re: pipemax [Re: mopar dave] #925869
02/10/11 10:44 PM
02/10/11 10:44 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Primary length is under PRIMARY SPECS and Collector length is under COLLECTOR SPECS.
Re: pipemax [Re: mopar dave] #925870
02/10/11 10:46 PM
02/10/11 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They are saying 3.63 for diameter and 17.2 total collector
length from the end of the primaries to the end of
the collector
EDIT
and I would say the VE on the head is too high at
100... more like 94 to 96
Re: pipemax [Re: S/ST 3040] #925871
02/10/11 10:47 PM
02/10/11 10:47 PM
Mt Morris Michigan
Mt Morris Michigan
the primary tubes i understand,but where are they measuring the collector length from?
Re: pipemax [Re: mopar dave] #925872
02/10/11 10:48 PM
02/10/11 10:48 PM
S/ST 3040 Offline
S/ST 3040  Offline
The end of the primaries to the end of the collector.
Re: pipemax [Re: S/ST 3040] #925873
02/10/11 10:53 PM
02/10/11 10:53 PM
Mt Morris Michigan
Mt Morris Michigan
ok, reading from the page. header collector specs(conventional straight tube) tuned lenght=17.5, so 17.5 is measured from the end of the 4 primaries to the collector flange? what is the 8.7 and the 34.9?
Re: pipemax [Re: mopar dave] #925874
02/10/11 11:00 PM
02/10/11 11:00 PM
S/ST 3040 Offline
S/ST 3040  Offline
Those would be other "tuned lengths" but, at a different harmonic.
Re: pipemax [Re: mopar dave] #925875
02/10/11 11:05 PM
02/10/11 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... I was wondering... I was sure I seen 17.5 on the
length but didnt see you put up a second chart changing
the compression to come up with a 17.2
Re: pipemax [Re: MR_P_BODY] #925876
02/10/11 11:12 PM
02/10/11 11:12 PM
Mt Morris Michigan
Mt Morris Michigan
mr p. i guess i really dont know how to use this program. what do you me i need to put up a second page with more compression?
Re: pipemax [Re: mopar dave] #925877
02/10/11 11:21 PM
02/10/11 11:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
That's from the end of the primary tubes to where it dumps into the atmosphere.(incuding extensions)
Re: pipemax [Re: S/ST 3040] #925878
02/10/11 11:23 PM
02/10/11 11:23 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i just started playing with this. what should my VE be set to? i set it at 100%,but the hp looks alittle low.
Re: pipemax [Re: mopar dave] #925879
02/10/11 11:30 PM
02/10/11 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I said was... the difference of the 2 pages
was the compression.... one is 13:1 the other is 10.6:1
giving you the difference in the collector length.
You'll have to learn(and read the book) to get a
idea on the VE... most people will guess high on it
by at least a few points... thats why I ask the flow
and make of head to help figure VE
Re: pipemax [Re: MR_P_BODY] #925880
02/10/11 11:36 PM
02/10/11 11:36 PM
Mt Morris Michigan
Mt Morris Michigan
thanks mike. the problem is that i dont have a book. i bought the program from the wallace racing site. so,looking at the charts are my 1 7/8 TTI's with 3" col. gonna work better with a 3.5" collector?
Re: pipemax [Re: mopar dave] #925881
02/10/11 11:46 PM
02/10/11 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should be able to click on VE and get help...
the 3.5 collector will be better.... most any shelf
header the primaries are too long and the collector
is too small and too short... they do this for packaging
and for cost... they arent made for max power but
it also allows it to be connected to a exhaust easier
EDIT
Also you can call the company and get the book
Re: pipemax [Re: MR_P_BODY] #925882
02/10/11 11:54 PM
02/10/11 11:54 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
all I have ever seen in Pipe Max deals in specifics like VE which when given a guess that produces another guess. Collector length IMO can only be on the money when testing on the track.For my 604 it old me to use a 2.4 first tue primary for steps
home of the
Sox and Martin Hemi Duster
Re: pipemax [Re: HEMIFRED] #925883
02/10/11 11:59 PM
02/10/11 11:59 PM
Mt Morris Michigan
Mt Morris Michigan
thanks mike.
Re: pipemax [Re: HEMIFRED] #925884
02/11/11 12:13 AM
02/11/11 12:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know the spec you entered in Fred but usually
you will find that the more efficient it is the smaller
the primary is... and of all the stuff I've ever worked
with it never called for a 2.4 1st primary so I would
doubt the input data.... JMO... but with all the
stuff I have run with the program then built the
headers and ran them on the dyno I would say the
program is good
Re: pipemax [Re: MR_P_BODY] #925885
02/11/11 01:25 AM
02/11/11 01:25 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
not sure who did it but I think could have been someone here based on specs and 1179 hp @ 7400 850 tq.
home of the
Re: pipemax [Re: HEMIFRED] #925886
02/11/11 10:43 AM
02/11/11 10:43 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What exactly is port center line length?
