Re: Can I eliminate ballast resistor? [Re: Mike H] #925250
02/11/11 03:44 PM
02/11/11 03:44 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
P2444641 Mopar .25 Ballast
Re: Can I eliminate ballast resistor? [Re: Azzkikrcuda] #925251
02/11/11 07:15 PM
02/11/11 07:15 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I have a few ballasts laying around and was just thinking...Is the resistance measured as obvious as it looks ???...The .25 should read .25 correct ???{none seem to be reading the exact values we're discussing} Are these units all over the place on resistance or do I just have some old, used pieces ????
Re: Can I eliminate ballast resistor? [Re: screamindriver] #925252
02/11/11 07:41 PM
02/11/11 07:41 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I think it's pretty common to have the resistance be out of spec, all of mine that I've checked were off to some degree, some by quite a bit!
Re: Can I eliminate ballast resistor? [Re: tt76400] #925253
02/11/11 09:32 PM
02/11/11 09:32 PM
there's alot of wiggle room there. Just keep in mind coil longevity and spark output are inversely proportional (keep spare of each in the glove box )
