Re: upper ball joint
[Re: 70RT Charger]
#924029
02/09/11 09:50 AM
02/09/11 09:50 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
If you pounded it out with a hammer the arm is probally shot.They are threaded thats why you need the socket.I would almost say the arm is bad anyway.Something had to be wrong with that arm to start with.They dont usually want to come out even with the socket.Rocky
Chrysler Firepower
[Re: therocks]
#924032
02/10/11 04:13 PM
02/10/11 04:13 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I borrowed the socket to fit the other ball joint and it threaded out just fine.Compared the threads to the other upper control arm and didnt appear to be stripped.So I took the other ball joint and threaded it back into the control arm that I beat out.It tightened up just find without stripping out.
[Re: 70RT Charger]
#924033
02/10/11 04:34 PM
02/10/11 04:34 PM
Posts: 75,128 A Banana Republic near you.
JohnRR
Wait till you put some miles on it , don't be surprised when it pops out .
[Re: JohnRR]
#924034
02/10/11 10:28 PM
02/10/11 10:28 PM
70RT Charger
eastern,Ky
John,you guys were right.The guy that I borrowed the socket off of came by the house,I showed him the upper control arm.I thought it was ok because it tightened up.He said let me see,he turned it upside down and said,lets say your traveling down the road and hit a pot hole,he took my 2 lb and smaked it one time and it popped.Made me feel stupid,so now Ill be getting another control arm.Lesson learned.
[Re: buildanother]
#924041
02/11/11 11:25 PM
02/11/11 11:25 PM
RapidRobert
I'd find a competent welder and have him weld em together ten ways from Sunday. they'll stay together and you're not going to b reusing the UCA & you'll have a way to work and can find a good UCA in your leisure
[Re: Jwilli500]
#924044
02/12/11 11:06 PM
02/12/11 11:06 PM
70RT Charger
eastern,Ky
A Tack weld or four might be OK, but I wouldnt put too much heat in 'em as they might not be all steel. Some ball joints may have partial or all Polymer bearing surfaces inside. http://www.aa1car.com/library/ball_joints.htm
Im pretty for sure the Moog BJ has neither inside and is all metal to metal not for sure though.
