Re: My first hemi project [Re: JohnRR] #922696
02/20/11 09:16 PM
02/20/11 09:16 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I went out to the shop this morning and began measuring, found the bores were perfect 4.5, then I measured the pistons, middle of the skirt, they were .009 smaller. After the shop warmed up some, the pistons were only .006 smaller. For forged pistons, seems ok but are way looser than any Hyper's that I have worked with in the past. Tim
Re: My first hemi project [Re: astjp2] #922697
02/20/11 10:07 PM
02/20/11 10:07 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Tim, that's a forged piston not a hypereutectic.
Re: My first hemi project [Re: CRE2004] #922698
03/02/11 11:37 PM
03/02/11 11:37 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I ordered my crank and rods, K1 for both. I have enought left over for a balancer now and hopefully a flywheel soon. I had the heads flowed, they are ok, I was hoping for better though.
Re: My first hemi project [Re: astjp2] #922699
03/10/11 07:45 PM
03/10/11 07:45 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Got a Mopar performance steel ring balancer, my machinist has had 2 fluid ones fail, the silicone solidified. Now I am trying to get rockers and a cam figured out. Tim
Re: My first hemi project [Re: astjp2] #922700
03/25/11 08:36 PM
03/25/11 08:36 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well I ordered the cam today, got in the mopar performance water pump, Oil cap and PVC cap, windage tray, rockers are on the way, stock rockers with Dvorak stands, low miles used. Machine shop got the block cleaned up and the K1 crank and rods clear great! The fuel pump is not fitting so far. I am down to roller lifters, pushrods, manifold and carbs, and distributor!
Re: My first hemi project [Re: astjp2] #922701
02/17/12 01:25 AM
02/17/12 01:25 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well my engine is still not running, but its 95% assembled. I had to use the milodon road race pan with the external pickup. The last part I need to buy for the engine is the external oil line. I am having http://www.woolfaircraft.com/ build the line. After an hour of bending 3/8" line, I got a good pattern to have it made from 3/4" 304 stainless tubing. I will keep you posted on the progress. Tim
Re: My first hemi project [Re: astjp2] #922702
02/17/12 02:25 AM
02/17/12 02:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A year later and you aren't done ??? I've only been building my hemi since 2005 ...
Re: My first hemi project [Re: JohnRR] #922703
02/17/12 12:01 PM
02/17/12 12:01 PM
GA
roadrunninMark Offline
GA
Are you using the main studs and bolts that came with that world block??? Before you build it, there is a thread on here about those studs/nuts you should read. I would get a set from ARP just to be safe.
Re: My first hemi project [Re: roadrunninMark] #922704
02/18/12 05:09 AM
02/18/12 05:09 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That would be this thread.
https://board.moparts.org/ubbthreads/show...0&fpart=all
My World Hemi block is at the engine builder right now. Dan Smith, Qwkmopardan on here.
It had the no name studs in it, I'll never understand why they installed no name studs but used ARP nuts.
The studs were replaced before the line bore was checked.
It was a little tight and had to be opened up, or so I was told.
Re: My first hemi project [Re: SNK-EYZ] #922705
02/18/12 10:54 AM
02/18/12 10:54 AM
GA
GA
for no name studs and arp nuts ("sniff sniff" smells funny)
you for checking it out
Re: My first hemi project [Re: roadrunninMark] #922706
02/18/12 01:38 PM
02/18/12 01:38 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
did anyone ever check what those studs realy are?
i mean instead of just bein upset they dont say ARP on them,doing some reserch as to what they are and what is wrong with them
Re: My first hemi project [Re: 1Fast340] #922707
02/18/12 01:57 PM
02/18/12 01:57 PM
JohnRR Offline
JohnRR  Offline
You obviously didn't read the thread(s) about the subject, they are what one would call BUTTER bolts ....
They stretched too much and some failed before reaching torque spec if I remember right .
Re: My first hemi project [Re: JohnRR] #922708
02/18/12 03:15 PM
02/18/12 03:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
nope never did,some of these threads just ends up being with not alot of value,instead of being productive.
ok butterbolts sounds real bad,cant realy see why world would ship them out like that
