Re: My first hemi project
[Re: astjp2]
#922700
03/25/11 08:36 PM
03/25/11 08:36 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well I ordered the cam today, got in the mopar performance water pump, Oil cap and PVC cap, windage tray, rockers are on the way, stock rockers with Dvorak stands, low miles used. Machine shop got the block cleaned up and the K1 crank and rods clear great! The fuel pump is not fitting so far. I am down to roller lifters, pushrods, manifold and carbs, and distributor! ![](/ubbthreads/images/graemlins/apimp.gif)
[Re: astjp2]
#922701
02/17/12 01:25 AM
02/17/12 01:25 AM
astjp2
Utah and Alaska
Well my engine is still not running, but its 95% assembled. I had to use the milodon road race pan with the external pickup. The last part I need to buy for the engine is the external oil line. I am having http://www.woolfaircraft.com/ build the line. After an hour of bending 3/8" line, I got a good pattern to have it made from 3/4" 304 stainless tubing. I will keep you posted on the progress. Tim
[Re: 1Fast340]
#922707
02/18/12 01:57 PM
02/18/12 01:57 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
did anyone ever check what those studs realy are? i mean instead of just bein upset they dont say ARP on them,doing some reserch as to what they are and what is wrong with them
You obviously didn't read the thread(s) about the subject, they are what one would call BUTTER bolts ....
They stretched too much and some failed before reaching torque spec if I remember right .
[Re: JohnRR]
#922708
02/18/12 03:15 PM
02/18/12 03:15 PM
Posts: 2,578 sweden
1Fast340
sweden
nope never did,some of these threads just ends up being with not alot of value,instead of being productive.
ok butterbolts sounds real bad,cant realy see why world would ship them out like that ![](/ubbthreads/images/graemlins/shock.gif)
