Re: 70 roadrunner 383 or 440 ?
[Re: mikemee1331]
#922412
02/07/11 02:27 PM
02/07/11 02:27 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
i honestly think us guys in the middle would not see much of a difference, performance wise, between a 440 and a 383.
This isn't rocket science; the 383 and 440 are the same basic engine using the same heads, ect. If you were to build your engine to a nice 1hp per cu then the 440 is going to have 57 more hp all things being equal and that is too much to ignore.
I'll put it another way: you'll give up approximately 15 percent going with the 383.
So, if the choice is between a bone stock 383 or a bone stock 440 and correctness isn't an issue then the choice to go with a 440 is a no-brainer......BUT, If I had an original 383 RR, I would build a 383 or 400 stroker to retain the B engine but with an RB kick.
![](/ubbthreads/images/graemlins/Twocents.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
