Re: sadi roller vs billet roller with bronze gear [Re: 602heavy] #922255
02/07/11 02:03 PM
02/07/11 02:03 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Well , if you got a comp cam with the part# ending in -9 & it is'nt a billet core then you've been screwed over. .......maybe call comp cams & tell them the issue you had........Goldmember , did'nt you post something on speed talk regards this issue?
Nope. It's not an issue to me,just trying to pass along info that may help someone down the line. If someone other than Stanton needs this info just PM me with a phone # and I'll go over it again. Many comp cams ending in -9 that are cast cores(NOT ALL),catalog is incorrect,not a big deal for the application. Just don't like to hear the garbage being spewn as fact,although it's not uncommon. Can you tell which is the -9?
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922256
02/07/11 02:48 PM
02/07/11 02:48 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Billet on the right?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922257
02/07/11 02:55 PM
02/07/11 02:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Watch the language!! This thread is about to go away!!
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922258
02/07/11 03:21 PM
02/07/11 03:21 PM
UK
602heavy Offline
602heavy  Offline
UK
Must of been an issue as you would'nt of posted over on speed talk , if i rememmber correctly you got no reply to you're question. ............ fact is the -9 IS a billet core , just because you got sent/sold the cast core does'nt mean we should all be aware -9s are NOT billet , the one on the left of you're picture is obviously a cast core .
Re: sadi roller vs billet roller with bronze gear [Re: 602heavy] #922259
02/07/11 03:51 PM
02/07/11 03:51 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I ask about cores as I noticed comp was using cast cores with the -9 tag,yes, 4 different comp suppliers confirmed this. For that build I really wanted a 2pc core,which after working with Comp they were able to locate(although crane being done they had only a couple left) and I let them grind that cam. If I had ordered the same pn with that magical-9 through Jegs,Summit,etc I would recieve a CAST core as most running a hyd roller would be fine with that choice. For those that guessed the right was a -9 you were wrong,thats a crane billet(comp billets are -9),for those that guessed the cam on the left,you win!! Comp hyd roller cast core -9.Would you want a billet hyd roller cam and the pain of using a bronze gear on a mild build? I think several of you just missed my point completely.
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922260
02/07/11 04:05 PM
02/07/11 04:05 PM
UK
602heavy Offline
602heavy  Offline
UK
You're pretty hard to please Goldmember.
Re: sadi roller vs billet roller with bronze gear [Re: 602heavy] #922261
02/07/11 04:11 PM
02/07/11 04:11 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Maybe but the point,once again for those that didn't get it. -9 doesn't insure a billet core. Some say it must,it doesn't.There are hundreds and maybe thousands running around with a cast core and a -9. Got that? I made it as simple as possible.GGGEEEEZZZZZZ
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922262
02/07/11 05:14 PM
02/07/11 05:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm going to carefully step around the above and state exactly what I know on this subject:
1. There are no BBM / 426 Hemi billet cam cores w/ cast-iron gears pressed on available from any core source.
2. Although there have been cast cores used for performance roller cam applications for other brands, they have been given the by many engine builders because they don't hold up as well w/ the higher spring pressures that go along w/ those applications. You can do a search on cast roller cams on SpeedTalk.com to see some examples of this.
3. The only choice I have seen offered for hydraulic or solid rollers w/ a BBM or 426 Hemi is a billet steel cam that requires using the bronze distributor drive gear. I'm not thrilled about that either, but it is what it is at this time.
Re: sadi roller vs billet roller with bronze gear [Re: sublimehemi] #922263
02/07/11 05:19 PM
02/07/11 05:19 PM
UK
602heavy Offline
602heavy  Offline
UK
so guys are you sayin that if i do get an sadi cam ....a stock type steel gear will work
If the Sadi uses a cast core then a standard distributor gear will work , some of the GM/Chevy guys use a melonized distributor gear when using steel cores , i've never seen a melonized gear for our Mopars but i could be wrong , would'nt be the first or last.
FWIW i used a bronze distributor gear on a billet roller , 800lb spring pressure over the nose , this engine was used on the street @ covered around 6K miles with no wear issues , high volume oil pump using 20/50 valvoline , rock solid ignition timing that never moved , most times it was sitting in traffic idleing.
Re: sadi roller vs billet roller with bronze gear [Re: BradH] #922264
02/07/11 05:40 PM
02/07/11 05:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Although I have been told(not verified!) that Ruben cams(grinds for others) has other core options. Again,I have no evidence to back this up.
Re: sadi roller vs billet roller with bronze gear [Re: 602heavy] #922265
02/07/11 05:43 PM
02/07/11 05:43 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"If the Sadi uses a cast core then a standard distributor gear will work , some of the GM/Chevy guys use a melonized distributor gear when using steel cores , i've never seen a melonized gear for our Mopars."
Re: sadi roller vs billet roller with bronze gear [Re: goldmember] #922266
02/07/11 06:56 PM
02/07/11 06:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ok, goldmember, I have no problem having an argument, being told I'm wrong or even admitting to being wrong - when I am! However, all along I've merely been quoting the Comp catalog. Your statement below CLEARLY absolves me of any error.
You owe me an apology. I don't think you're man enough!
Re: sadi roller vs billet roller with bronze gear [Re: Stanton] #922267
02/07/11 07:09 PM
02/07/11 07:09 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"all along I've merely been quoting the Comp catalog." "Your statement below CLEARLY absolves me of any error." There's your problem. You believe everything you read,whether it's on the internet or in a catalog,it can easily be wrong. I'm not picking on you. If you think I owe you anything your sadly mistaken. A 4yr old with major ADHD can see that. I'll go down the street and borrow one(4 yr old ADHD kid) to confirm it if you like.
Re: sadi roller vs billet roller with bronze gear [Re: Stanton] #922268
02/07/11 07:27 PM
02/07/11 07:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: sadi roller vs billet roller with bronze gear [Re: JohnRR] #922269
02/07/11 07:32 PM
02/07/11 07:32 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Now you come along and make me spew a cola out of my nose. Thanks
