048 & 054 Radiator Questions #921298
02/04/11 10:38 PM
02/04/11 10:38 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
I need a 048 radiator for a 68 I just acquired and just found a 054 that is available and for a 69, the 054 has fittings on the bottom tank for the internal trans cooler.
My question is: The 048 radiator, do you know if these are suppossed have fittings on the lower tank like the 054 radiator? My 68 has an auto and has the external cooler mounted in front of the radiator, the rad in my car right now is from a 70 383-440 and I want to put it back to the original Hemi Radiator.
Car is enroute so I can't tell you what my rad looks like other then the car has been driven with it for a couple of years now.
I was figuring on having the 054 redone to original specs and see if I could do a trade for a correct 048 which I need for my car.
Thanks Folks,
Gibby
Re: 048 & 054 Radiator Questions [Re: zrwhat] #921299
02/05/11 01:39 AM
02/05/11 01:39 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Yes, the 048 will have the fittings on the bottom for the lines. I can't say if the spacing will be the same but, if not, you can get the right lines. The 054 should be able to be parlayed easily into an 048 because it may be in more demand. I'm in NOVA also.
Re: 048 & 054 Radiator Questions [Re: RoadRunnerJD] #921300
02/05/11 05:15 AM
02/05/11 05:15 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
There is an 048 for sale in the B body parts..
Automatic cars had fittings, manual cars had plugs in the fittings..
Glen Ray radiators make a great 048 Radiator...
Re: 048 & 054 Radiator Questions [Re: zrwhat] #921301
02/05/11 12:00 PM
02/05/11 12:00 PM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Other than the part # and the date code, they are physicaly the same in every way. In my experience(sp) the 048 is about the hardest good used radiator to find. I myself wouldn't restore/recore a 054 in hopes to trade for a 048.
Bob
Re: 048 & 054 Radiator Questions [Re: radiatorman] #921302
02/05/11 12:45 PM
02/05/11 12:45 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
Thanks guys, this is the kind of information I was hoping to find.
Did see the 048 for sale here on the board but kinda pricy for something that probably will need to be recored, paying for the numbers I know. Have looked at the Glen-Ray units and they are looking better and better, can't go wrong with new-new and just trying to get closer to original then it is now, never going to be a show car or trailer queen, It will be used and driven....
Gibby
Re: 048 & 054 Radiator Questions [Re: zrwhat] #921303
02/05/11 01:10 PM
02/05/11 01:10 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Gibby
Then just use the 054 you have unless it needs a recore, when you get into numbers and date codes be prepared to OVERPAY for it .
Re: 048 & 054 Radiator Questions [Re: JohnRR] #921304
02/06/11 12:09 PM
02/06/11 12:09 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
JohnRR,
planning on recoring it to be on the safe side, I will probably install it and maybe something will come along in the mean time.
Anybody know of any 048's that are realistic in price, let me know.
Gibby
Re: 048 & 054 Radiator Questions [Re: zrwhat] #921305
02/06/11 01:22 PM
02/06/11 01:22 PM
Warrenton, VA
Warrenton, VA
The 054 was out if the car from 1981-2005. I just had it pressure tested. It was fine so I installed it and I have had no cooling problems with it. A nice core with the correct fins per inch is expensive and I don't think the average radiator shop will be able to get an OE type core? If it works, I wouldn't get it recored. If it's a nice original, maybe you could sell it for enough ( plus your cost savings of recoring) to buy a new repro?
Re: 048 & 054 Radiator Questions [Re: RoadRunnerJD] #921306
02/06/11 01:49 PM
02/06/11 01:49 PM
JohnRR Offline
JohnRR  Offline
new repro is about 1200 , he's not going to get that for one that needs to be restored , if he does ... at the buyer ...
Re: 048 & 054 Radiator Questions [Re: JohnRR] #921307
02/06/11 02:42 PM
02/06/11 02:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
JohnRR,
Gibby
Please define "realistic".
There are two styles of 054 radiators, small font and large font, demand for either varies as does the price. Generally speaking the 048 is less common and much harder to find than either 054, you won't likely find anyone willing to trade you straight up for one. As far as restoration costs, Glen-ray makes the $1,200.00 reproductions (I'm a vendor for them), they are a VERY accurate first rate product. They also do the best restoration work you'll find on originals, (accurate looking cores and better cooling than original) usually costing about half as much as a new reproduction if you provide a good set of core tanks and side straps.
Re: 048 & 054 Radiator Questions [Re: JohnRR] #921308
02/06/11 03:38 PM
02/06/11 03:38 PM
Warrenton, VA
Warrenton, VA
[quote...new repro is about 1200 , he's not going to get that for one that needs to be restored , if he does ... at the buyer ...
I think it would work out if he could sell it for $600 or more and save the $600 on a recore and then you have your net of $1200 for a repro 048 instead of wasting time and $ recoring the wrong radiator in the first place?
Re: 048 & 054 Radiator Questions [Re: ScottSmith_Harms] #921309
02/06/11 04:15 PM
02/06/11 04:15 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
This ones for you John and please enjoy the laugh . My name is Mark and I'm a Mopar addict. It is my drug of choice. I've been informed that this disease is incurable. Last fall I paid 10K for an 048. Yes 10K ! I believe that's an all time record. At times it sickens me to see what some parts sell for but this is my hobby and if I can save a few bucks to buy what I want so be it. I always justify it by saying I could be pouring the money down the urinal or up in smoke. Of course the 048 came bolted to a barn fresh 1967 GTX. That 048 is going to be used in my 68 Charger when I install the new crate Hemi in it some day. Not too long ago, Bob at Glen-Ray hooked me up with a super great deal on an original correct 67 Hemi radiator for the 67 GTX (THANKS Bob!). Although it was a deal I couldn't refuse, I'm radiator poor now...I looked for a deal on an 048 for nearly 18 months and the cheapest one I found was $800.00 and most likely probably would have needed a core as it was completely original. The only other 048 I've seen for sale has been the 048 in the Moparts parts section for 1K. To the OP, if you have to have the correct numbers, sell the 054 and then pay the differnce and have Bob at Glen-Ray build you a new 048 you won't regret it . I sure miss the days of old combing the junkyards and usually finding the parts you needed, unfortunately those days are long behind us.
Re: 048 & 054 Radiator Questions [Re: JohnRR] #921310
02/06/11 05:06 PM
02/06/11 05:06 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
Core has had some bumps in the finned area both front and back so I'd probably have the core replaced and just use it since I'm not chasing numbers, just trying to get it closer to correct then it is currently.
Gibby
Re: 048 & 054 Radiator Questions [Re: badblack68] #921311
02/06/11 05:12 PM
02/06/11 05:12 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
[ To the OP, if you have to have the correct numbers, sell the 054 and then pay the differnce and have Bob at Glen-Ray build you a new 048 you won't regret it . I sure miss the days of old combing the junkyards and usually finding the parts you needed, unfortunately those days are long behind us.
BB68,
Good advice, probably the way I'll go and save the 054 for whatever.
Re: 048 & 054 Radiator Questions [Re: badblack68] #921312
02/07/11 02:10 PM
02/07/11 02:10 PM
JohnRR Offline
JohnRR  Offline
I'm laughing at you because you can't READ ... I said no one is going to pay 1K for an 054 needing a recore/restore ...
Re: 048 & 054 Radiator Questions [Re: JohnRR] #921313
02/07/11 05:45 PM
02/07/11 05:45 PM
badblack68 Offline
badblack68  Offline
Read? I can barely write/type and standing upright is a challenge.
Re: 048 & 054 Radiator Questions [Re: badblack68] #921314
02/07/11 06:17 PM
02/07/11 06:17 PM
JohnRR Offline
JohnRR  Offline
