Re: Dyno... 4 motors, 3 days.
[Re: 340RICK]
#920514
02/03/11 11:53 PM
02/03/11 11:53 PM
Posts: 242 Upland, California
Spode
Upland, California
Thanks Ryan Your threads are the most interesting on this site. Not that others are boring it just that I love the technical and empirical aspect of building engines. In another life I would love to do the work you do. Thanks
[Re: fishy340]
#920516
02/04/11 12:25 AM
02/04/11 12:25 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
dying to see the big dog in a few weeks
The "big dog" is going to be my buddies W8 @ 17:1. Joe's will make power, but it's just an 11:1 pump gas Nitrous motor, so it won't be anything outrageous, probably 790-800. Will make alot of TQ... Should make at least 675-680 TQ. The W8 will probably be over 720 TQ.
Joe said the W5 made 440 on chassis dyno, so that's about 530-540 Crank, which seems about right. The heads were basically stock with real mild exhaust port work & a valve job.
[Re: Leigh]
#920517
02/04/11 12:33 AM
02/04/11 12:33 AM
RyanJ
moparts member
moparts member
State College, PA
Did the freshened engine show reversion, and did it disappear with the replacement headers?
? That's the whole point of the Graph on the W7 motor... The header reversion is what is killing the power on the pulls marked Custom header VS the traditional header. It's not a back pressure issue IMO, although I wish I had a way to measure BP in the collectors on that one, it's more of a pressure pulse issue. Basically @ certain RPM's the headers start to reverse flow. Quickest way to kill HP is to dilute the intake charge with exhaust gases. The back side of intake valves looked like exhaust valves... The reversion was all the way up into the manifold runners.
[Re: fishy340]
#920525
02/04/11 08:03 PM
02/04/11 08:03 PM
Posts: 6,195 Melbourne , Australia
LA360
I have seen similar results with custom headers myself. One example a 331 cube Ford Windsor that ran faster with the exhaust on, and a 340 Chrysler that was just down on power. After trying jet and timing changes, changing carbs, even lash while we were at it on the Ford engine we threw on a set of off the shelf headers with the same primary size and diameter collector. Picked up around 30hp. Bolted the custom headers back on and added some length to the very short collectors and picked up most of the gain made with the shelf headers.
The 340's headers just plain had the wrong sized collector which we were able to make custom collector extensions for to get a reasonable number out of it.
Those custom headers shown and Ryan's dyno headers have a look at how different they are, especially note how the tubing exits off the head.
Alan Jones
[Re: LA360]
#920526
02/04/11 08:27 PM
02/04/11 08:27 PM
RyanJ
moparts member
moparts member
State College, PA
Yes they are drastically different exit out of head, & obviously the header with the most generous straight path is best, but almost all underchassis headers make substantial turn right out of head (like a TTI etc) But they do not cause a pulse reversion issue like this set. Yes they kill some overall power, but they don't kill 1200 RPM of useable powerband & cause a reversion issue like this.... There is major difference between a header than just loses 30 HP overall, & one that causes the engine to basically reverse flow above a certain RPM.
Here are a pair of dyno Sheets off of a motor I did a while ago with these same Dyno headers & then pulled them off & put a set of TTI 1 7/8 W2 headers on.....This is pretty "normal" loss due to tight exit angle, little bit too small of collector etc.
Look @ the power #'s, really did'nt change the powerband, just changed how much was made. The W7 header was basically just trying to shut the motor off...
Here is Pull of 436" Motor with The Schoenfeld Dyno headers:
[Re: mopar dave]
#920531
02/06/11 05:04 PM
02/06/11 05:04 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
ok, so what off the shelf w2 street car style header makes the best power? i'v been using the 1 7/8 TTI,but been thinking about getting something different. i'v had two pairs of TTI's and when looking into the collector notice on both pair the tubes to be different lengths where they come together in the collector. does'nt look right. every pair of hookers i'v looked in are all even.
theres a set for sale by outlaw,in the for sale section of moparts there on mike's w2 motor thats for sale also...me i want the w8 motor
[Re: RyanJ]
#920532
02/06/11 06:39 PM
02/06/11 06:39 PM
Posts: 6,005 Anoka County, MN
Leigh
Anoka County, MN
Finally looked at this. So, you saw visible reversion evidence in the intake of the freshend engine? I ask this, as usually, an A, B, A, comparison, is the benchmark of diagnostics. Not trying to be an A S S. I have an invested interest, as my intake manifold and exhaust side shows heavy reversion. Thanks, Leigh
