Re: lightweight working headlights
[Re: Monte_Smith]
#919954
02/04/11 04:11 PM
02/04/11 04:11 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
If you need 7 inch round ones. Try a late model Jeep Wrangler. They are light weight plastic, use a modern hi-output bulb and reflector and they bolt right in.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: 493_DART]
#919957
02/04/11 09:21 PM
02/04/11 09:21 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i weighed a 7" bulb and it was 1lb 3oz and 5.75 bulb was 11oz
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Leigh]
#919959
02/05/11 02:51 PM
02/05/11 02:51 PM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
napa sells the kits. you can get a 7" round plastic LED light, with bulb , and connector to adapt to stock plug for 89.00 per side. i would imagine you could get non LED and be much cheaper. hope this helps
It's a bigblock with a torque flight!!!
[Re: fullmetaljacket]
#919961
02/06/11 10:26 AM
02/06/11 10:26 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I bought some off Ebay.I had them in my 57 and a set in the 65.My kid has a set in his 62 300 also.They are the plastic ones with the replacebale bulbs.One set has been in at least 9 years and still clear as when he installed them.Mine 4 years.All the cars are street driven.No relay needed.The relays Ive heard are a good upgrade though.The Halogen bulb actually draws less amps.Just dont try to run something like a 100/200 watt bulb.I run 55/100 in all of mine.I even have them in the Harleys.Rocky
Chrysler Firepower
