Re: Help needed with an electrical nightmare
[Re: feets]
#919344
02/13/11 01:53 PM
02/13/11 01:53 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
I replaced the battery to chassis ground. That didn't fix it. I'm getting 12.5 volts at the battery with the engine off and 14.5 volts with it running.
But isn't that 14.5 volts while the ammeter is reading normal (charge) and NOT bouncing around or showing discharge? I am thinking dirty/sticky/worn alternator brushes.
[Re: Sixpak]
#919346
02/14/11 03:53 PM
02/14/11 03:53 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Digging through the factory diagrams it looks like all in-cab electrical stuff grounds through the body of the healight switch.
I fiddled around with it this weekend. The fuse box has three buss bars in it. One of them runs the door locks and A/C. Both are high amperage consumers. There was enough voltage at the bus to turn on a trouble light. I pulled the fuse (circuit breaker actually) for the windows and jumped power from another bus bar to the output side of the fuse. The windows worked fine and did not turn on the trouble lights. This tells me that it's an amperage supply issue and not a ground. I will have to go through the power supply and bulkhead connector to look for issues. I'm strongly considering replacing the fusible links with fuses.
I guess I'll go through everything while the dash is out. Put the blower motor on a relay, replace the fusible links with fuses, and improve the dash lighting.
[Re: stumpy]
#919348
02/14/11 06:09 PM
02/14/11 06:09 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Think before replacing the fusible links with fuses because the fuses won't be able to deal with the spikes that links will. The starting draw on some of the acessoties is higher than the fuse ratings.
True on the voltage spikes.
I installed a 100a circuit breaker on my dedicated 6ga charging wire. On two occasions it's tripped for no apparent reason.
I rather click it back over than hunt for a fuse, or wire in a new link however.
[Re: stumpy]
#919349
02/14/11 07:15 PM
02/14/11 07:15 PM
feets
Senior Management
Senior Management
Irving, TX
Looking at the gauge of wires they used a 30 amp fuse should work. If it presents an issue I can switch to drop in 30 amp circuit breakers.
There are three fusible links going into the fuse block. I planned on replacing each of them with a fused lead. If I put the blower motor on a relay for high speed it will take a big load off the fuse block. They are known to melt fuses and fuse blocks. My headlamps are already on relays.
[Re: ph23vo]
#919351
02/15/11 02:43 PM
02/15/11 02:43 PM
feets
Senior Management
Senior Management
Irving, TX
I've gone through the grounds, alternator, and battery.
It's got to be the power source. A bad ground wouldn't suddenly get better when you supply a new power source.
