Page 2 of 5 1 2 3 4 5
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915341
01/27/11 11:18 PM
01/27/11 11:18 PM
Washington
SuperStock68Dart Offline
Washington
Don't use tubes or screws! Beadblast or "rough up" the bead area of your wheels and use a paint brush with Dawn dish soap! Coat the inside of the tire with the soap let dry, mount up and race!!!
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915342
01/27/11 11:20 PM
01/27/11 11:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run screws in every bias ply tire I run(havn`t tried radials yet)so as to keep the tire from slipping on the rim and to help keep the bead seated. No tubes EVER for me and they leak very little when it sits for a couple of weeks. Next step............bead locks; Can`t imagine the high hp 6-second cars NOT running screws or locks.
Re: when to put screws in the rims for slicks [Re: SuperStock68Dart] #915343
01/27/11 11:26 PM
01/27/11 11:26 PM
okla.
sam64 Offline
sam64  Offline
okla.
yeah they won't have that problem again,i guess it works for those that use em and those that don't.
Re: when to put screws in the rims for slicks [Re: sam64] #915344
01/27/11 11:44 PM
01/27/11 11:44 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I quit running tubes years ago just because I had 2 valve stems rip off the tube and quickly lose air, could be dangerous. I think this happened because the hole in the wheel didn't properly line up with the valve stem on the tube.
I use Dawn dish soap and no tubes, and I use 8 screws on each side of the wheels. I saw a Mustang wreck many years ago from breaking a bead.
I've heard that running 16 screws on each side of each wheel will help stiffen the sidewall.
Also, I recently read that the screw should thread into the wheel, I didn't know that, the holes in my wheels have always been bigger than the screws so the screws just thread into the tire.
340Rick and Bobsprofab turned me onto a stainless screw that has a nice rounded head and uses a square drive bit, they look clean and can even be polished.
Re: when to put screws in the rims for slicks [Re: DaveRS23] #915345
01/28/11 12:33 AM
01/28/11 12:33 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I personally do not screw my rims since I stopped using tubes. Is there any reason anymore to screw the tires on unless you're running tubes?
If you have enough power and bite you can knock a bead out and the tire will go flat instantly. The lower the tire pressure the more likely this could happen-especially if you are "driving" the car. That's why faster NHRA cars are required to use beadlock wheels.
Re: when to put screws in the rims for slicks [Re: ProSport] #915346
01/28/11 12:40 AM
01/28/11 12:40 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Running 16 screws each side probably acts like a stiffer sidewall because you are anchoring the tire to the wheel more often, and closer together. I have notices some of the higher powered small tire cars are running more screws.
That "Square bit" screw you speak of is a Canadian invention It is called a "Robertson" Head. I really like them, much easier to use with out striping the head of the screw or the end of your bit.
-Kenny
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915347
01/28/11 12:43 AM
01/28/11 12:43 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
BEFORE this happens
Re: when to put screws in the rims for slicks [Re: ProSport] #915348
01/28/11 12:43 AM
01/28/11 12:43 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
On new slicks I just soap them up with dawn soap and put them on, run them till the side walls are leaking air to the point that air is needed every day, then install the tubes. I prefer to screw them on. If the tubes are installed properly you won't rip out the stems. Use plenty of tire talc inside a dry clean slick, that means all the soap residue must be flushed out or your tube will stick and rip.
Re: when to put screws in the rims for slicks [Re: rowin4] #915349
01/28/11 01:26 AM
01/28/11 01:26 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i found if you go racing the day after you fitted your slick, you would see a few inches of movement. if you fitted your slick a couple of weeks before you go racing you'll see very little movement if any. i put this down to the soapy lube they apply to help your slick fit over the rim & slip onto the bead is still wet so it allows movement. i used to screw just the back of my rim as to hide the screws, but in the last 2 seasons we've gotten a bit lazy & haven't bothered to screw at all. i'm not seeing any movement & we still mark the rim to check at each meeting. i'm doing 9.4's at 139 mph with 1.34 60's in a 2950lb car with me in the chair.
Re: when to put screws in the rims for slicks [Re: rebel] #915350
01/28/11 01:54 AM
01/28/11 01:54 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Brand new mounts will tend to slip. Older mounts will be stuck like glue/weld. mike
Re: when to put screws in the rims for slicks [Re: actionange] #915351
01/28/11 02:15 AM
01/28/11 02:15 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I run 9 x 28 M/T's with tubes on an 8 inch rim with 18 lbs of air. They aren't screwed to the rims. Been doing this for the past 6 seasons without any issues. The tubes keep the tire stiffer at launch and all the way down the track.
This is dangerous right here. If the tire ever happens to slip on the wheel, it will likely rip the stem out of the tube and you will be in for a rough ride, straight into the wall. I understand you have done it for 6 years. But all it takes is once.
Personally, I think people are nuts, not to anchor the tire to the rim in some way, but thats just me. Last year at an ADRL race, I saw a driver get after an XTF car too hard in the water and knocked both rear tires off the beads. Thats how fast it can happen
Monte
Re: when to put screws in the rims for slicks [Re: SuperStock68Dart] #915352
01/28/11 02:44 AM
01/28/11 02:44 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Do they run screws in the rims in NASCAR ?
Re: when to put screws in the rims for slicks [Re: bigdad] #915353
01/28/11 02:47 AM
01/28/11 02:47 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
No they have inner-liners
Re: when to put screws in the rims for slicks [Re: SB412DUSTER] #915354
01/28/11 02:52 AM
01/28/11 02:52 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
This I know but, what keeps the tire on the bead ?
Re: when to put screws in the rims for slicks [Re: bigdad] #915355
01/28/11 07:31 AM
01/28/11 07:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
ties are stiff sidewalls, not anywhere near what we run. they also run steel wheels.
Re: when to put screws in the rims for slicks [Re: Quicktree] #915356
01/28/11 08:50 AM
01/28/11 08:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have done it both ways... no screws and no tubes...
I did mark the tire to the stem and mine moved all
the time... thing was I never knew if it went a few
inches or a few turns... then I switched over to running
tubes and screws... this currant set up has yielded
my best 60ft with a 1.19 and I think its the stiffer
side wall....also I get more runs out of a set of tires...
I never get rid of the tires due to being worn out
(tread surface) but the side walls giving out and
when they start going I see the 60 ft going away.
So for me its a better set up all around with tubes
and screws..... my opinion is if you have a big tire
with low pressure you COULD be asking for problems
Re: when to put screws in the rims for slicks [Re: DaveRS23] #915357
01/28/11 10:37 AM
01/28/11 10:37 AM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I agree, I have a buddy runnin 8.60's in a 2800# car and when he spent $450 a piece on new rims he sure wasn't gonna drill hole in them. We marked the wheel/rim and it moved about 1/2" after the first pass then never again.
Re: when to put screws in the rims for slicks [Re: Monte_Smith] #915358
01/28/11 11:19 AM
01/28/11 11:19 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Monte
I really don't know what these guys are thinking. Maybe they just haven't seen this stuff happen themselves.
Re: when to put screws in the rims for slicks [Re: bigdad] #915359
01/28/11 11:20 AM
01/28/11 11:20 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Apples to oranges comparison.
Re: when to put screws in the rims for slicks [Re: StrokerAspen] #915360
01/28/11 12:11 PM
01/28/11 12:11 PM
Az
Crizila Offline
Crizila  Offline
Az
What is the rule of thumb of when to put screws in the rims when using slicks ? what ET or power level or always?
Also what if you don't would it cause problems with valve stem on the tubes tearing off ?
thanks
We talked about putting screws in wheels at the Dave Morgan Chassis Seminar that I attended. There are a lot of factors to consider that get over looked. Things I would have never thought of.
For starters, You want to "Index" your screws. Basically, where ever you put a screw on the front side of the wheel, make sure you put the screw on the back of the wheel directly across from the screw on the front of the wheel. If the screws are staggered , this will cause the car to "wonder". Mis-aligned (staggered) screws tend to want to "twist" the tire, as the tire is being pulled from those points at where it is screwed to the rim.
Here is the best picture I could find in my library. SORRY it isn't a Mopar.
You can see that the wrinkle is pulling from where the screw is on the wheel.
Second, how many screws do you put in the wheel? That depends on how big or small you want the "paddle" of the tire to be. Watch some of the high horsepower cars, and the tracks they make out of the whole. you can see the tire is "paddling" the ground. If the screws are further apart, the "paddle" is bigger, the closer the screws are, the smaller the paddle it.
for example....
5 screws around the diameter of the wheel will make for large paddles, but fewer paddles (4 paddles)
10 screws around the diameter of the wheel will make for smaller paddles, but more paddles (9 paddles)
What is the right amount of screws for a car? That I don't know. I personally haven't run screws. My tires seem to hook up just fine with out them.
-Kenny
Good info. Thanks!
Fastest 300
