Re: PS Box Moving While Turning Steering Wheel [Re: YO7_A66] #914798
01/27/11 09:30 PM
01/27/11 09:30 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Glad you caught it in time...It's amazing that it can come loose like that and be relatively undetected...
Re: PS Box Moving While Turning Steering Wheel [Re: screamindriver] #914799
01/27/11 09:45 PM
01/27/11 09:45 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I have had the car for 9 years and never once thought to tighten the ps box bolts. I am thinking of pulling them back out and adding either lock washers or locktite.
Re: PS Box Moving While Turning Steering Wheel [Re: 62maxwgn] #914800
01/27/11 09:46 PM
01/27/11 09:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Before jumping to any conclusions or being paranoid,just check the bolts first.
Glad you found it and was a easy fix. 62maxwgn was right on!
Re: PS Box Moving While Turning Steering Wheel [Re: YO7_A66] #914801
01/27/11 10:13 PM
01/27/11 10:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They should have lockwashers , as far as huge clearance holes , no but the box walking around could make them bigger . I'd pull each one , clean the bolt and the hole with brake wash , blow them out then use red loctite and torque to spec .
Re: PS Box Moving While Turning Steering Wheel [Re: JohnRR] #914802
01/27/11 11:24 PM
01/27/11 11:24 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I was thinking blue but there is no reason for me to be pull the ps box any time soon. I will pick up some red this weekend. It is hard to tell how long this box has been moving around on me and I don't want it to happen again.
Re: PS Box Moving While Turning Steering Wheel [Re: YO7_A66] #914803
01/27/11 11:41 PM
01/27/11 11:41 PM
IMGTX Offline
IMGTX  Offline
Glad it was a simple fix.
When the previous owner had my GTX the box broke completely loose and he could only turn left. If he turned left the box wedged up against the frame if he turned right it walked over to the side of the block instead of movign the tires.
The scary part is he drove it like that for abotu 2 months every day.
Re: PS Box Moving While Turning Steering Wheel [Re: YO7_A66] #914804
01/28/11 03:05 AM
01/28/11 03:05 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
Good to hear it was just the bolts. You should notice the steering has less slop in it when the bolts are tight.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: PS Box Moving While Turning Steering Wheel [Re: YO7_A66] #914805
01/28/11 11:42 AM
01/28/11 11:42 AM
JohnRR Offline
JohnRR  Offline
You should have much trouble getting that size bolt out with red in the future , breaker bar or impact gun .
Re: PS Box Moving While Turning Steering Wheel [Re: JohnRR] #914806
01/28/11 01:55 PM
01/28/11 01:55 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I'd still suggest throwing on a few gussets at some point down the line. Try turning the wheel with the pump going this time, I bet you see movement.
