Big Big motor!! #914612
01/26/11 06:55 PM
01/26/11 06:55 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
SONNY LEONARD TOPS 1000 CID WITH NEW ENGINE
Written by Bobby Bennett Wednesday, 26 January 2011 08:40
There’s big and then there is Sonny Leonard big.
Leonard, a veteran engine builder from Lynchburg, Va., is building what he believes to be the largest drag race engine ever at 1005 cubic inches.
Did the veteran engine builder ever believe the day would come?
“Absolutely not,” Leonard said on Thursday morning. “[Years ago] I couldn’t have even comprehended that.”
Leonard, who has built a solid reputation for supplying mega-inch-displacement engines to mountain motor Pro Stock, Pro Modified and fast doorslammer racers, believed early into his business that engine displacements would likely peak in the 500 cubic inch range.
Leonard was building engines as large as 540 cubic inches back in the 1970s.
“I believed back in those days that engines could only get about 540 or 550 tops,” he admitted. “Those were mountains back then but in today’s world, they are effectively molehills.”
Back in those days the leading proponents of the massive displacement engines were not only Leonard, but Pat Musi and the legendary “General” Lee Edwards.
As overwhelming as the 1005 cubic inch engine is, Leonard isn’t naive enough to believe that it’s the end all of engine displacements. He definitely sees even larger on the horizon with the continual refinement of the technology.
“It takes two things, time and money,” admits Leonard. “If we could put a man on the moon and bring him back over 40 years ago, anything is possible.”
The general consensus amongst engine builders is that the larger the displacement, the less efficient it will be. For instance, Leonard believes an engine displacing in the range of 500 inches will more times than not be more efficient than one displacing twice as many cubic inches.
However, for brute horsepower in a car weighing 2350 pounds, size does matter. And truth be known, the outer dimensions on the 1005-incher will be the same as the 904-inch beast he completed last year.
“This engine is capable of running 8,000 rpm which was unheard of five years ago,” Leonard explained. “The door is open here. It might not be as efficient but it will go quicker. If it was weight per cubic inch, this wouldn’t be the way to go.”
Leonard is building this monstrous powerplant for Craig Olson and his CEO Racing team sponsored by Rescue Voice.
According to Leonard, the engine will be naturally aspirated and feature Sonny’s Racing Engines new fully in-house CNC-ported special Edition GM Hemispherical Cylinder Heads.
The heads on this 2150 horse engine will feature Sonny’s Ultimate Pro Stock porting. Other engine components includes SAR custom titanium valves, PSI springs, Sonny Bryant billet crankshaft, GRP billet aluminum rods, mammoth SAR/ custom pistons with special ring package, SAR/CE 1.062 keyed lifters, 1.031 tool steel taper-wall pins, SAR/T&D.
The mega-inch engine will also feature a Jesel shaft mounted rocker system, Jesel belt drive, Custom Dailey 7 stage lightweight dry sump oiling system, ATI balancer, MSD Ignition, SAR sheet-metal Pro Stock intake featuring SAR/ Accufab Throttle Bodies.
The engine will be equipped with a custom Big Stuff electronic fuel injection system, a set of billet valve covers from Moroso and an MSD Pro Series Starter.
The engine is based on a special SAR billet aluminum block with a 2-inch raised cam to accommodate the custom 70 mm camshaft.
Leonard estimates the engine will weigh about 675 pounds with an EFI system. The average 500-inch engine typically weighs in the 550 pound range.
“It will catch a lot of eyes and it will go plenty fast,” Leonard added.
Re: Big Big motor!! [Re: Harley] #914613
01/26/11 08:04 PM
01/26/11 08:04 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Hopefully this starts a whole new arms race.
Re: Big Big motor!! [Re: POS Dakota] #914614
01/26/11 08:21 PM
01/26/11 08:21 PM
organ
maximum entropy Offline
organ
this news pleases me.
Re: Big Big motor!! [Re: Harley] #914615
01/26/11 08:43 PM
01/26/11 08:43 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
...and will use a Mopar Dakota mini starter.
If you like drag racing, support your local track.
Re: Big Big motor!! [Re: maximum entropy] #914616
01/26/11 10:39 PM
01/26/11 10:39 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Sounds cool for sure, but I'm kinda surprised at the 2100 HP level.
I know it's alot of power, but I expected it to be alot more for the trouble of engineering a huge engine.
codfish
Re: Big Big motor!! [Re: codfish] #914617
01/27/11 08:30 AM
01/27/11 08:30 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
That's over 2 hp per c.i. How many engines do you know that can make that NA?
This post is available in double vision where drunk.
Re: Big Big motor!! [Re: bwdst6] #914618
01/27/11 09:42 AM
01/27/11 09:42 AM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
!!!WOW!!!
Good thing he's got "GM" hemispherical heads on that thing. Imagine if he didn't......it might struggle to make 1000....without those "GM" hemispherical heads!!! Obviously a "GM" shortblock as well, no doubt.
What a farce.....anything to make a certain crowd happy I guess. Thing is, there are probably dolts out there that actually fall for it.
Re: Big Big motor!! [Re: jim sciortino] #914619
01/27/11 06:13 PM
01/27/11 06:13 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
!!!WOW!!!
I was thinking the same thing,nothing GM about that motor.
Re: Big Big motor!! [Re: jim sciortino] #914620
01/27/11 11:37 PM
01/27/11 11:37 PM
Lehigh Acres, Florida
rickstershemi Offline
!!!WOW!!!
Yeah like "Ma Mopar" designed the hemispherical head.....not
They were originally designed and in use in the early 1900's
Rickster
Re: Big Big motor!! [Re: rickstershemi] #914621
01/27/11 11:44 PM
01/27/11 11:44 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
That engine is coming to the northwest and going in this car.
Re: Big Big motor!! [Re: rickstershemi] #914622
01/27/11 11:46 PM
01/27/11 11:46 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I wonder how many more he would sell if he made a "mopar" version...but i doubt he cares about doing that.
Re: Big Big motor!! [Re: B1Fish540] #914623
01/28/11 12:13 AM
01/28/11 12:13 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
...so if the earth stopped rotating, that would be what you use to re-start it?...
Re: Big Big motor!! [Re: bill_greenwood] #914624
01/28/11 12:15 AM
01/28/11 12:15 AM
IN
ahy Offline
ahy  Offline
IN
Any basic specs... bore, stroke, bore spacing?
Re: Big Big motor!! [Re: ahy] #914625
01/28/11 09:25 AM
01/28/11 09:25 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I can't help wondering what would happen if Sonny and Nelson got together one time and build something even more insane...
Re: Big Big motor!! [Re: BigBlockMopar] #914626
01/28/11 02:15 PM
01/28/11 02:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Allen Johnson just came out with some new Hemi heads with wide bore spacing to be able to build some very large Mopar Hemi's.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Big Big motor!! [Re: ChrisJohnston669] #914627
01/28/11 02:38 PM
01/28/11 02:38 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Is that going in a Tamez car?
Those motors have some serious maintenance issues. We were thinking of going that way with a N/A combo but had second thoughts after speaking to some guys who run the 900 cube version.
Re: Big Big motor!! [Re: BobR] #914628
01/28/11 03:28 PM
01/28/11 03:28 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Re: Big Big motor!! [Re: rickstershemi] #914629
01/28/11 04:25 PM
01/28/11 04:25 PM
Trumbull,CT.
Trumbull,CT.
!!!WOW!!!
Rickster
Who said Ma Mopar did???
Reading comprehension problem??? You do know IT'S ADVERTISING........right???
There comes a time when NOTHING resembles ANYTHING.......this is one of those times. Capice???
Re: Big Big motor!! [Re: BobR] #914630
01/28/11 11:14 PM
01/28/11 11:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
Nope, Owner and driver is Craig Olson. Defending Top Sportsman champ up here in D6. The Tamez crew runs some big stuff, but not this big.
FWIW the car already runs 6.70-6.80. Supposedly he ordered a new car to handle this beast.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Big Big motor!! [Re: jim sciortino] #914631
01/28/11 11:53 PM
01/28/11 11:53 PM
!!!WOW!!!
Rickster
No reading comprehension problems here....just call'm as I see'm which is pretty obvious here
Rickster
