Re: 440 Stroker Kit?
[Re: Flatblack]
#913174
01/24/11 11:02 PM
01/24/11 11:02 PM
Posts: 643 southern conn
1969gtx
southern conn
nick at compu-flow very knowledgable i have purchased 2 kit from him 528 kits http://www.compu-flow.com/
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: Flatblack]
#913175
01/24/11 11:07 PM
01/24/11 11:07 PM
Posts: 2,648 GA
Boosted
GA
I have the 512 from 440 source and love it...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: RapidRobert]
#913181
01/25/11 02:22 AM
01/25/11 02:22 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Can you use the 400 block for either the 512 or 528 kit??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 72N96RR]
#913182
01/25/11 10:05 AM
01/25/11 10:05 AM
Posts: 2,648 GA
Boosted
GA
I am using the stock 440 block with my 512... No issues at all. went together like a stock 440 would...
2011 RAM3500
[Re: KillerBee]
#913184
01/25/11 01:04 PM
01/25/11 01:04 PM
Posts: 8,890 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
considering one in the future. why would you have gone w lesser cubes? More compression height for longevity?
Comp. ht. wasn't a concern ... its a stroker motor !!!
Primarily so as not to have to bore the block .055 over. The 528 uses a 4.375 stroke crank. I could have gone with a .030 or .040 bore but then the bore would have been less than the stroke.
Going with the 4.25 stroke crank you can go .030 over and the bore is larger than the stroke. This, by the way, yeilds a 505"
The 528 uses a 4.375 stroke crank so an external oil system is almost a must. Clearancing the block for the longer stroke was no big deal at all but it did need it.
And no matter what I ran the numbers through, the 512/505 made the same HP and Torque as the 528 (which turns out to be 526 with the .055 overbore).
[Re: chrisf]
#913187
01/25/11 03:46 PM
01/25/11 03:46 PM
Posts: 996 Queens, New York
Harley
Queens, New York
i see ohio crankshaft sells as well. anyone ever buy their stuff?
I have the 4.25 crank form ohio. It checked out good, and it's been in my motor for 5 years now.
[Re: Harley]
#913188
01/25/11 10:34 PM
01/25/11 10:34 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I just ordered the 512 kit and heads today from 440 source. Ken told me the 512 was a better choice than the 493 that i was going to go with.The 512 should yeild about 10.25 compression where as the 493 was going to be about 11.5.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#913189
01/25/11 11:52 PM
01/25/11 11:52 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I have that exact kit and heads in my 440! It performs really good! But now I want more power!
[Re: Blakcharger440]
#913190
01/26/11 12:16 AM
01/26/11 12:16 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Call them back and upgrade to the CNC'd heads (if its within your budget)- otherwise you're no further ahead than using a stock 906!
When you get the heads you'll DEFINATELY want to upgrade the retainers and locks and possibly the springs depending on your cam choice.
Did you get the "balanced" assy. - worth the few extra bucks!
Also, don't be disappointed if/when the pins don't fit the rods ... this is about the only thing that needs attention.
