Re: 70 hp440 ???? [Re: AB&E] #912945
01/25/11 10:49 PM
01/25/11 10:49 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
F440 A.... ....So where does the HP fit into all this ???
Re: 70 hp440 ???? [Re: screamindriver] #912946
01/26/11 12:13 AM
01/26/11 12:13 AM
washington
AB&E Offline OP
AB&E  Offline OP
washington
sorry F 440 A the a is sideways above the 0
bottom line is 1 23 HP
This is whats on top pad
Re: 70 hp440 ???? [Re: AB&E] #912947
01/26/11 12:06 PM
01/26/11 12:06 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
also here is the partial vin any idea what motor was in originally.
0 215237 cast date 11/06/69
pad info f440 A
1-23
thanks for info
Is this someones 70hp440 thats missing on here?? I could sale it
Would you also be willing to SELL it ???? or are you offering it on SALE from your original price ???
It's going to be hard to find it's original owner when you didn't provide ALL the stamped info ? Is there and HP on the top pad ? You left out the build plant off the VIN on the side ....
Re: 70 hp440 ???? [Re: AB&E] #912948
01/26/11 01:56 PM
01/26/11 01:56 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Johnrr is right on all counts.
Here is info and pics on the dampers to identify your balancer;
http://www.440source.com/dampers.htm
I shouldn't confuse the issue by telling you that I was able to balance my '70 F440HP internally still using the factory 6 pack rods, necessitating the use of a non "6 Pack" damper......
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 hp440 ???? [Re: DPelletier] #912949
01/26/11 02:46 PM
01/26/11 02:46 PM
I have a 440 at home with the big rods and is internally balanced also , just took small pieces of mallory in the drilled holes , was not very expensive to have done.
Re: 70 hp440 ???? [Re: JohnRR] #912950
01/26/11 04:08 PM
01/26/11 04:08 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
pad info f440 A
1-23
thanks for info
I Do not have motor for sale its going in my car 6pk style unless someone here has the car it came out of.& needs it really really bad $$$$ via partial vin# thats all of the numbers. and thats enough #s to tell if its your motor.also there was never a price mentioned. and look at posts motor is stamped hp & it does have six pack dampner complete motor missing nothing & running
thanks
Re: 70 hp440 ???? [Re: AB&E] #912951
01/26/11 06:48 PM
01/26/11 06:48 PM
thanks
here is the VIN you posted
0 215237
That is not the complete VIN , it's missing the plant code , every single plant that built cars will have 1 engine with the numbers you posted AND a letter between the zero and 2 for the plant that stamped and installed it.
Re: 70 hp440 ???? [Re: JohnRR] #912952
01/26/11 09:07 PM
01/26/11 09:07 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
there is a space where it would be i will look closer tonight but even with my seeing glasses on & flashlight there is a blank spot after the 0 weird a
hey can i use my neutral balance 11" flywheel on my motor & have it balanced? ya know I talked to tony d about this & he said to use it & not to worry about balancing it
whata ya think about that
thanks marty
