Page 11 of 16 1 2 9 10 11 12 13 15 16
Re: 430" small block build [Re: Abodyjohn88] #912822
06/04/12 12:40 AM
06/04/12 12:40 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I am surprised you didn't machine the cap and shorten the main stud rather than use a bolt. Nice looking build, will be interesting to see the various results
Alan Jones
Re: 430" small block build [Re: LA360] #912823
06/04/12 08:37 AM
06/04/12 08:37 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
After considering all directions, the determination was that there was not alot of stress on the back cap, unlike a chev, with the thrust , oil pump, rear seal & bearing back there...lol.
There are proven packages making almost double with the stock bolt back there, so I was completely comfortable with it.
Re: 430" small block build [Re: DJVCuda] #912824
06/04/12 09:28 AM
06/04/12 09:28 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
ok - time for the recap
get 5 gallons of Sunoco Ultra 93 and headed over to make some pulls
We bolted the engine up the day before so we were ready to make some pulls when we got there.
It fired right off - good sign!
Made the first pull after a warmup, set timing, and check for leaks.
No oil or water leaks were a damn good sign of things when we were warming it up.
1st pull was mild as we were seating the rings, as well as making sure the Holley Ultra HP 750 was jetted close.
With everything good to go the hammer went down - we made the pulls from 3000 to 5600 as it started dropping off after that.
What we wound up with was:
511.7 hp @ 5400
566 ft/lbs @ 4200
Flat torque curve does not describe this motor - there was 519 ft/lbs @ 3000 and stayed over 500 ft / lbs until 5400
That's averaging 515 ft/lbs for the entire run!
We changed the carb to an 830 & got within 1 hp of the 750 - seems to me the carb is not limiting the engine at this point.
I was surprised that a stock casting eddy head could pull that much power, I was expecting under 500 for sure.
I'm kinda glad things were uneventful in terms of problems, it was just an easy Sunday afternoon!
Re: 430" small block build [Re: DJVCuda] #912825
06/04/12 10:14 AM
06/04/12 10:14 AM
Montgomery, Texas
O
OneRunSon Offline
OneRunSon  Offline
O
Montgomery, Texas
nice numbers what headers did you use and did yall try any spacers?
Fred Vandiver
Re: 430" small block build [Re: OneRunSon] #912826
06/04/12 10:23 AM
06/04/12 10:23 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
1 5/8 hooker comps were on there for testing - I didnt want to waste any time with a larger tube and a stock head.
I tried a few spacers, but it really didnt change much - I tried a couple 1" but with similar results.
I really thought one carb setup would walk away from the other but it really didnt...
Re: 430" small block build [Re: DJVCuda] #912827
06/04/12 10:37 AM
06/04/12 10:37 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Thanks for sharing.
What ignition box and coil did you use?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 430" small block build [Re: Rapid340] #912828
06/04/12 10:46 AM
06/04/12 10:46 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Thanks for sharing.
MSD Dist & coil ( E-Curve ) locked out at 30 degrees ( where it liked it the most )
Re: 430" small block build [Re: DJVCuda] #912829
06/04/12 10:58 AM
06/04/12 10:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Granted thats alot of cubes for a set of stock heads
but I wonder if your choke was the 1 5/8 headers...
hard to say... if you cant get it out you cant get
it in... nice torque out of it
Re: 430" small block build [Re: MR_P_BODY] #912830
06/04/12 11:04 AM
06/04/12 11:04 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Very good point. The next test should shine some light on that as I have a set of ported heads & a victor 340 with the same cam & headers.
Re: 430" small block build [Re: MR_P_BODY] #912831
06/04/12 11:13 AM
06/04/12 11:13 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
hard to say..
I'd think even with untouched Edelbrocks that 1 5/8" headers, no matter who makes them, would kill any performance stroker. If it was a truck motor they'd probably be fine.
Re: 430" small block build [Re: LA360] #912832
06/04/12 11:18 AM
06/04/12 11:18 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
cool build , im subscribed
Re: 430" small block build [Re: justinp61] #912833
06/04/12 12:09 PM
06/04/12 12:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice #'s Dave. Thats gonna run great. Hope to see you at Carlisle. Ron
Re: 430" small block build [Re: 383man] #912834
06/04/12 08:21 PM
06/04/12 08:21 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Thanks Ron!
I wont be at Carlise this year, I am starting a renovation soon and probably wont have the time.
Re: 430" small block build [Re: DJVCuda] #912835
06/05/12 10:19 AM
06/05/12 10:19 AM
Montgomery, Texas
O
OneRunSon Offline
OneRunSon  Offline
O
Montgomery, Texas
dave, hope you can also run the air-gap dualplane with the ported heads. would be interesting to see the differences between the victor and dualplane. thanks for sharing info
Fred Vandiver
Re: 430" small block build [Re: OneRunSon] #912836
06/05/12 10:29 AM
06/05/12 10:29 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
it really comes down to time - and what I can fit in on dyno time.
Got it swapped over, but got bumped for a bit so others can get on the dyno
Re: 430" small block build [Re: DJVCuda] #912837
06/05/12 10:34 AM
06/05/12 10:34 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
impressive numbers man!
...makes me think I might build another smallblock rather than do up a bigblock...lol
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 430" small block build [Re: OUTLAWD] #912838
06/05/12 10:36 AM
06/05/12 10:36 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I tell you what - as much as It is like a Buick motor - thats one hell of a street motor - 500 ft/lbs from the hit of the converter?? what a tire fryer...lol
Re: 430" small block build [Re: DJVCuda] #912839
06/05/12 10:50 AM
06/05/12 10:50 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I did the same thing. It's really no problem.
Re: 430" small block build [Re: POS Dakota] #912840
06/05/12 02:05 PM
06/05/12 02:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I do the Bolt in #5 too
Nice build, a set of Shady Dell stage 2 Eddies would work Perfectly with that cam, Mine is 266/269 @.050 but similar .585/570 Lift. With a roller cam they would probably net you close to +50hp with no downside. Not sure if the OOTB RPM intake would flow quite enough up high on that big a motor without some work though (I run a ported Vic 340), but your peak power would probably raise another 400-500RPM.
BTW...I'm also running a way too small 1 5/8" x 3" header but that's because I'm not sure a 1 7/8" x 3 1/2 (the size I run on my 427" SBF) would fit the chassis, bang for the buck the cheapies do just fine
Stock Small block Edelbrocks
LIFT-----IN/EX
.200”--131.1/107.0
.300”--182.9/151.8
.400”--216.6/181.2
.450”--227.7/182.9
.500”--235.9/185.6
.550”--238.7/185.6
.600”--242.2/185.6
.650”--243.2/185.6
.700”--243.2/185.6
SDSS ported Flow #'s Gain
LIFT--IN/EX
.200"--146.9/110.8 15.8 3.8
.300"--196.3/150.1 13.4 -1.7
.400"--245.8/180.2 29.2 -1
.450"--259.0/193.8 31.3 9.9
.500"--268.6/203.4 32.7 17.8
.550"--271.8/212.9 33.1 27.3
.600"--276.6/218.6 34.4 33
.650"--283.5/221.6 40.3 36
.700"--286.6/223.8 43.4 38.2
Re: 430" small block build [Re: Streetwize] #912841
06/05/12 03:37 PM
06/05/12 03:37 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Been waiting for your reply Wize -
I've got a stock victor 340 as well as Ryan's heads ready to make some pulls with this cam - and it is a solid roller.
As far as the intake goes - I was real impressed with the results from it - tons of torque and it made over 500 hp - i honestly was expecting a 450 horse motor with the intake / head / header setup I was running.
