Re: 430" small block build
[Re: ademon]
#912804
03/15/12 02:06 PM
03/15/12 02:06 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Long overdue update! I've been plugging away at the motor, bottom end is assembled and we're getting on the top end soon... cant wait! Both stock and ported eddy's were CC'd ( intake, exhaust, & chambers ) before we flowed them ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0535.jpg) Also got the crank balanced - we needed almost 170 grams off both sides and instead of drilling the hell out of the crank we milled off the weight. There are a bunch of ways to get this done but this is a better result then the drill at that amount. ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0564.jpg) You can see this SBF was drilled to death - not the most professional way to get it done. ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0618.jpg) With assembly right around the corner I whittled away at the oil pump and passages - the filter area and rear cap took the most work - here is a progress shot. ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0637.jpg) With everything clean we file fit the rings... getting there! ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0728.jpg) HOME SWEET HOME!!! ![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_0773.jpg)
[Re: DJVCuda]
#912807
05/20/12 10:22 PM
05/20/12 10:22 PM
DJVCuda
Atco NJ
![](http://i932.photobucket.com/albums/ad164/DJVJR75/SMALL%20BLOCK/DSC_1636.jpg) Should be on the dyno this week with a mild configuration any guesses? 430 cubes stock eddy heads air gap intake Comp XR286R LS 110 Intake Duration @ .050" Lift: 248 Valve Lift: .576 Exhaust Duration @ .050" Lift: 254 Valve Lift: .582 I have a couple carbs to try out - 750 ultra hp, 830, 950 hp and 1000 hp... still undecided.
[Re: pittsburghracer]
#912810
05/21/12 10:16 AM
05/21/12 10:16 AM
DJVCuda
Atco NJ
Earlier in this post I thought you said you were going to use ported heads with 2.05 valves.
I will be - I am dyno'ing several configurations - this is the mildest build
[Re: DJVCuda]
#912811
05/21/12 10:29 AM
05/21/12 10:29 AM
Posts: 1,178 Indy
FlyFish
Indy
I run that same cam in my 410 stroker. I bet you get ~ 530 hp with a pile-O torque.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: DJVCuda]
#912817
06/03/12 09:32 PM
06/03/12 09:32 PM
DJVCuda
Atco NJ
