Page 5 of 16 1 2 3 4 5 6 7 15 16
Re: 430" small block build [Re: BobR] #912702
01/26/11 08:35 PM
01/26/11 08:35 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
care to comment on the side loading - side discussion here then?
dealing with the long stroke at almost 10 grand has to show you alot if there was an issue.
No issue at all. Of course we rebuild our motor about every 30-40 passes.
You guys are talking about a 4.25" stroke. We couldn't put that much stroke in our Ford motor due to rod to cam clearance. Read that we don't have enough. We have to slightly grind the big end of the rods for 4.09 stroke.
Re: 430" small block build [Re: BobR] #912703
01/26/11 08:37 PM
01/26/11 08:37 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
And here I am complaining if I have to rebuild mine in a year.
Re: 430" small block build [Re: Devilbrad] #912704
01/26/11 09:07 PM
01/26/11 09:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Closest comparison I can hands on relate to is I've built a number of Mitsu turbos to about 2Bar or ~30psi. Mitsubishi 4g63's have short rods ~(1.6 IIRC) and long strokes too and (believe it or not) can make close to the same (4-5 HP/cube) and RPM as BobR's Ford.
Side loading primarily leads to accelerated ring and bore wear, (the durability "issue") and obviously that builds HEAT, scuffing of the pistons/bores can happen in ANY motor if the oil film breaks down/cokes and the engine load is high enough for long enough.
Excessive side loading?, obviously not....I would only define Excessive as leading to damage and/or loss of power. But more side loading than an equivalent displacement 430" shorter stroke motor, definately. Not excessive but maybe significantly closer to it....
Those dart blocks have mega-thick walls compared to OEM, thinner bores move around more than thick ones.
bobR, do you have the 302 or cleveland Mains?
Just curious.
On a 9.5" deck windsor the big end of the rods do get up in the cam at anything over about 4" with steel rods, I have a 4.17" stroke 427 and also had to relieve the big ends and run a reduced base circle cam. the proximity is something you try not to think about when you're
WIZE
In Car:
Re: 430" small block build [Re: BobR] #912705
01/26/11 10:34 PM
01/26/11 10:34 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Bob, on other forums I've commented (and questioned) the combination of this low rod to stroke ratio on this package in regard to ring seal and ultimately life span... Any comment on a 1.3 compression height and 1.5 R/S? My assertion is that it should be expected to live a shorter life than a 4" arm and that the gain in power for that little more stroke isnt worth the expense.
Re: 430" small block build [Re: moper] #912706
01/26/11 11:29 PM
01/26/11 11:29 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
while i wont comment on the CH, RS ratio or any balancer issues ( LOL) I will tell you that I put the BPE crank, Pistons and compstar rods together cheaper then a 4" stock mopar rod sized combo - rod's pistons come with pins and rings and it was in fact cheaper then a standard 4" stroker combo.
Re: 430" small block build [Re: DJVCuda] #912707
01/26/11 11:42 PM
01/26/11 11:42 PM
So. Jersey
Somerdale Flash Offline
So. Jersey
Nice!
Re: 430" small block build [Re: Streetwize] #912708
01/27/11 12:41 AM
01/27/11 12:41 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"Those dart blocks have mega-thick walls compared to OEM, thinner bores move around more than thick ones."
-We also filled it and run no water through it at all. We do run water through the heads. Bore stability is critical to ring seal. With the aluminum Fontana block even when filled Vacuum would go from 16 hg at idle to positive through the traps. With the Dart it has at least 6 hg in the lights.
Just curious.
-Not sure what it has now. We've tried a few.
On a 9.5" deck windsor the big end of the rods do get up in the cam at anything over about 4" with steel rods, I have a 4.17" stroke 427 and also had to relieve the big ends and run a reduced base circle cam. the proximity is something.
-It is REALLY close. We use aluminum rods and we have to cut quite a bit. Hasn't seem to hurt the strength. YET.
Re: 430" small block build [Re: moper] #912709
01/27/11 12:45 AM
01/27/11 12:45 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Dave,
We ask our motor to live 30-40 runs so longevity isn't in the equation. Since there are other aspects of the piston/rod/stroke that are much more critical to making power we don't even concern ourselves with that stuff. BAE doesn't either. They have a shelf piston that works for almost everything. Compression is controlled by rod length.
Re: 430" small block build [Re: BobR] #912710
01/27/11 10:38 AM
01/27/11 10:38 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
wow - that makes you really appreciate the tall deck heights of a mopar - dont it?
thanks for the info.
Re: 430" small block build [Re: DJVCuda] #912711
01/27/11 12:44 PM
01/27/11 12:44 PM
K
kielbasa Offline
kielbasa  Offline
K
Very true....I am currently doing the same combo because of what you're getting for the price is hard to beat!
Re: 430" small block build [Re: kielbasa] #912712
01/27/11 09:14 PM
01/27/11 09:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Balancer issues...lol.
Re: 430" small block build [Re: moper] #912713
01/29/11 12:47 PM
01/29/11 12:47 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
anything new to report Vern.?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 430" small block build [Re: cheapstreetdustr] #912714
01/30/11 12:55 AM
01/30/11 12:55 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
went to the machine shop today - had a long day and have to upload pix and transfer measurements - but i'll fill you in asap
Re: 430" small block build [Re: DJVCuda] #912715
01/30/11 03:14 PM
01/30/11 03:14 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
OK - Whew - what a long day yesterday was - went to the machine shop for about 4 hours yesterday and got the following information:
Block - Sonic'd out good and magged good - .400+ on the thrust sides ( X block) and mostly 200 - 300 on the other sides of the cylinders.
after the steel shot machine the thing looks good as new -
Before :
After:
On to the Crank -
We checked a number of things to determine the overall quality and condition of the crank. - all measurements were taken at 62 degrees F
1 - straightness - .001
2 - OD of the Mains - 2.4998
3 - OD of the rod journals - 1.9995
4 - Taper of rods and mains - ( worst one ) .0002
5 - Out of round - NA
6 - OD of the snout ( to fit balancer later ) 1.532
7 - Stroke - we came up with 4.133" for all throws except one - that was the 3,4 journal and it was 4.134"
The stroke was longer then anticipated, and adds 2 cubic inches to the build, but they are all consistent with one being one thou longer.
We can play with deck heights to get thins to work out fine, so it's not an issue and the other measurements were impressive to say the least. I dont know if the colder temps ( 62 ) had anything to do with the measurements since i think the standard is in the 70's.
Just another thought when i got home last night I went to callies site and looked at the $1100 dragonslayer crank specs and what they guarantee their cranks to spec out at - here is the quote -
These shafts are machined to the tolerances demanded by today’s high performance engine builder. Roundness and taper are held to less than .0003 on all rod and main journal diameters. Our final polishing procedures produce excellent load carrying surfaces that ensure extended bearing life and trouble free operation.
So for half the price I got a crank within the spec of the Callies Dragonslayer - not bad in my opinion!
Last thing we checked for was the oiling holes were indeed drilled all the way - and they were!
Didnt want to leave any stone unturned with a new part and have an issue later.
BIG THANKS to Fonse Performance - they took good care of me yesterday!
Re: 430" small block build [Re: DJVCuda] #912716
01/30/11 03:39 PM
01/30/11 03:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Good news!
68 Barracuda Formula S 340
Re: 430" small block build [Re: Bad340fish] #912717
01/30/11 06:25 PM
01/30/11 06:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Thanks for this post. I'm planning a simular build w/my X block & indy 360-1 CNC.This is to out power my 408 W-5. What is your bore size going to be ? My X block has some core shift between the cylinders(.180-.200 thickness currently) and I will most likly offset bore that bank .030-.050 and fill w/hardblock.I was hoping to bore mine 4.1-4.125.Thanks again for the post & pictures.
Re: 430" small block build [Re: DavidDean] #912718
01/30/11 06:39 PM
01/30/11 06:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I doubt you get that much, sonic check it.
Re: 430" small block build [Re: DavidDean] #912719
01/30/11 10:37 PM
01/30/11 10:37 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I'm going 4.080 as of right now - i'll get it on the CNC machine shortly to check the dimensions out as we progress.
Re: 430" small block build [Re: DJVCuda] #912720
02/01/11 09:41 AM
02/01/11 09:41 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Should be on schedule this week to get the block on the CNC machine to check some points and hopefully bore and deck it.
After that if we have time the rotating assembly should be ready for balancing.
Re: 430" small block build [Re: DJVCuda] #912721
02/12/11 11:41 PM
02/12/11 11:41 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
well just a quick update- the deck was a mess when we put it on the ROTTLER CNC machine - 12 thousands off on the drivers side and 10 thousands off on the passenger side.
While the deck was flat - and this block was machined at a very reputable shop in the 80's the machinery of today has brought inconsistencies like this to the forefront of modern engine building.
so I had a flat, crooked deck on this sucker. But it will clean up within spec for the rotating assembly.
Speaking about the rotating assembly - It measured out to 1794.6 grams for the bobweight - nice and light!
Weights were consistent for everything :
Rods: +/- 2 grams - 599-601
pistons - +/- 1 gram - 471-472
Just out of curiosity - does anyone know the stock 340 rotating assembly bobweight?
The TCI Rattler had to be fitted to the crank which was 1.532" and the balancer was 2 1/2 thousands smaller - It was honed to fit with a 1 1/2 thou press fit.
so we're gettin there - slowly but surely.
