Re: Crower says no to Synthetic motor oil
[Re: dwayne welder]
#912196
01/25/11 04:34 AM
01/25/11 04:34 AM
Posts: 43,748 Bend,OR USA
Cab_Burge
I beleive a lot of the high dollar imports, Lexus, BMW, Jaguars, Mercedes Benz as well as some others come from the factory with pure sybthetic oils in the engines. I think that maybe some American cars do also, maybe not I know a lot of NHRA class racers swore that there cars pick up ET and MPH when they switch to multi viscoty synthetic oils
[Re: dartman366]
#912201
01/25/11 10:55 AM
01/25/11 10:55 AM
Posts: 8,166 Left Coast
BobR
Left Coast
I ran synthetic in my 8.75 a several of years ago, and did not like the scuffed look on the teeth, switched back to dino oil and problem went away.
Exact same thing with us. Now we use Dewco lube which isn't full synthetic.
[Re: BobR]
#912202
01/25/11 11:00 AM
01/25/11 11:00 AM
Posts: 1,752 detroit area
moderncylinder
detroit area
i use dewco,,, but probably bought the sales pitch from don,, plus maskin used it in their pro stock car..
i ran a hemi on teuton's dyno about 6 or so years ago,, i was given a bunch of mobil 1 syn oil,, like you buy at the parts store,, in the gray bottle,,, i ran the motor with 10-30 penzoil basic oil,, switched to mobil 1 and lost about 5avg horsepower. i thought mobil one was crap but then was told you need the red bottle,, thats the racing oil,, it has zinc in it... the gray bottles have almost no zinc,, ill never run mobil one in anything i own again,, its red line, valvoline vr, or joe gibbs
[Re: Cab_Burge]
#912203
01/25/11 11:01 AM
01/25/11 11:01 AM
BobR
Left Coast
Corvettes come with Mobil one for sure. Still don't think it's any better for regular use. Higher RPM for the same viscosity? I'd have to see that to believe it. No difference in my junk. It's better in extreme heat conditions that street or drag motors are unlikely to see.
[Re: moderncylinder]
#912204
01/25/11 11:06 AM
01/25/11 11:06 AM
BobR
Left Coast
I agree. Mobil one for the street is formulated for lower emissions. We use nothing but Brad Penn synthetic blend. Our crew chief/engine builder swears by it.
[Re: BobR]
#912205
01/25/11 11:41 AM
01/25/11 11:41 AM
Posts: 10,091 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My 528 did not like Mobil 1 on the dyno, lost 17 ft lbs torque. Tried Royal purple at the track, ABA test, RP cost me .1 ET. Back to conventional oil for me in the motor, Syn in the diff.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#912206
01/25/11 01:28 PM
01/25/11 01:28 PM
Posts: 7,506 Az
Crizila
Az
Amazing the different experiences people have. Wonder how many problems are really lube related . I run Royal Purple full synthetic in my 408. Three years now. Change it once a year. No abnormal wear or scuffing problems that I have noticed - and I have had several bad over heats due to blown belts. I usually run one or two grades lighter in viscosity than if I were running petroleum based oil. Definitely believe there is a friction advantage with synthetics - without film loss. I do run a zinc additive with it as I am running a large flat tappet hyd.
Fastest 300
[Re: Crizila]
#912207
01/25/11 01:56 PM
01/25/11 01:56 PM
BobR
Left Coast
I think that the last sentence to your post is the difference.
[Re: BobR]
#912208
01/25/11 02:08 PM
01/25/11 02:08 PM
Posts: 7,506 Az
Crizila
Az
Could be?? My edit was that last sentence. I guess that's my security blanket Been running the same flat teppet ( over .600 lift ) for 3 years now, so I probably don't need the additive anymore.
Fastest 300
[Re: Crizila]
#912210
01/25/11 02:13 PM
01/25/11 02:13 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
I have never ran an additive with my .672 flat tappet, just straight street Mobil 1 10w-30.
I just recently pulled the heads for more port work and bigger valves for my new stroker and the cam and lifters still look great. It's an older Hughes/Engle cam and lifters. 440# springs over the nose of the cam too. The Hughes recommended 330# springs wouldn't rev past 7500.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
#912212
01/25/11 04:01 PM
01/25/11 04:01 PM
Guitar Jones
how much extra oil do you guys put in with a fresh motor over what is usual once its been run? like if its got a 7 qt system do you put 7 in it fresh,, or 9? or??
I don't put extra oil in it, I think the chance for aeration would be much worse on an engine.
#912213
01/25/11 04:02 PM
01/25/11 04:02 PM
Posts: 7,506 Az
Crizila
Az
No extra. I run an 8 qt. pan and I run 8 qts. in it.
Fastest 300
[Re: Crizila]
#912214
01/25/11 06:12 PM
01/25/11 06:12 PM
moderncylinder
detroit area
well you have to fill the oil holes,, pushrods,, and wet the inside of the motor,,,, i usually see a qt and a half on my motor when its new,,, i pour in 9.5 qts,,, prime it,,, drain the pan and have 8 in the bucket..
i know a few guys who have spun bearings cause they put their motor together and just ran the "usual" amount,, which really was a qt or two low
