Re: 1100 HP out of a N/A small block
[Re: BobsProFab]
#912002
01/23/11 10:52 PM
01/23/11 10:52 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Dont know enough about P7 heads but with P5's I woudl think you could.
[Re: 5spdcuda]
#912003
01/23/11 11:12 PM
01/23/11 11:12 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
I would doubt it. Nascar cup engines are probably as highly developed as any n a two valve pushrod engine. Pro stock engines are probably comparable in terms of development. In any case 355 cid cup engines are generally thought to produce roughly 830-850 hp. At 850 hp a 355 cid engine is producing 2.394 hp per cu in. Since engines of the same basic design generally produce less hp per cube as the size goes up it seems to me that even with multiple carbs and freedom of design in the intake manifold 2.68 hp per cube at 410 cid would be very difficult to achieve.
Remember cup motors have flat tappet cams and small carbs with no valve train or induction restictions a good comp elimn engine builder may get close but it would be as high maintenance as a playboy bunny
[Re: biff426]
#912004
01/23/11 11:19 PM
01/23/11 11:19 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have a chevy canted valve engine 358cid that make's 975 so i would venture to guess yes its possible. Better buy lots of valve springs!
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#912006
01/24/11 12:36 AM
01/24/11 12:36 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Solid roller cam Sheetmetal tunnel ram Much higher compression ratio because you can use better fuel 55 more cubes Drag car can be built to use narrower TQ curve witch can allow you to build a higher peak HP number. Still with all that 300 more hp is a tall order but I think it could be done, and yes you will need lots of valve springs. Mabey you could mix your own e-85 with 15% 115 octane gasoline and 85% ethanol and that could add a few more HP by bringing in a little more oxygen than is possible with pure gasoline.
[Re: BobsProFab]
#912012
01/24/11 11:26 AM
01/24/11 11:26 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
Bob, I dont think you can get enough CSA in a P7 head. I would guess they are optomized for 358 cubes and thin to save weight. Bobo
BoBo to make that with a cup head already ported would be a tall order this would take a new casting with the right guy doing the work
Call Folts (CFE). They'll tell you if it's do-able or not.
[Re: STEFF]
#912013
01/24/11 11:31 AM
01/24/11 11:31 AM
Posts: 1,752 detroit area
moderncylinder
detroit area
patterson built a chevy using the best of the best,, 400 inches,, two dominators,, made a little over 1100
i think you can do it with two carbs,, not one
who will do the heads?
[Re: BobsProFab]
#912017
01/24/11 01:17 PM
01/24/11 01:17 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
...this would take a new casting...
I'm asking around, around here. Ya never know. I may be able to get some UGL cam cores too.
[Re: HardcoreB]
#912018
01/24/11 01:26 PM
01/24/11 01:26 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
cam will be a gun drilled billet peice and will take 1 inch lift ![](/ubbthreads/images/graemlins/shock.gif)
