Re: dmaddox's 1970 RoadRunner Restoration (first Mopar)
[Re: 68427vette]
#911607
02/24/11 09:16 PM
02/24/11 09:16 PM
Posts: 60 your fridge
dmaddox
your fridge
Hello again fellas..... I received some more parts (bushings and weatherstripping) today and I spent a few minutes after work fitting the trunk lid: Coming together!!
[Re: dmaddox]
#911608
03/10/11 12:03 PM
03/10/11 12:03 PM
dmaddox
your fridge
Hello everyone. Weatherstripping and bushings as well as door/fender/trunk hardware have finally arrived. I am in the process of fitting the panels and will spray the hood treatment on the cowling area soon. I am also wet-sanding and buffing in between larger projects. Hanging the doors: Obviously the torsion bars and front end will have to be adjusted/aligned.....I plan on having a slightly lowered front, but this is wayyyyy to low. Just an update! Thank you for any comments or criticism!
[Re: dmaddox]
#911609
03/14/11 11:00 AM
03/14/11 11:00 AM
dmaddox
your fridge
Not sure if anyone looks at this anymore, lol - regardless I thought I'd keep posting pictures of the progress. I am mounting the hood in preparation to paint the cowling area with organasol black. Sure is dusty in the shop . . .I promise some nice clean hi-def photo's very soon. WARNING!!! If you buy (notice above) the disk brake conversion kit from Jegs/Summit/etc... and you have a 70 RoadRunner....note that if you install it how they instruct you too, the hood will not shut. I had to lower it about 1/2" and adjust the pedal to accommodate this. The front-end section of the kit installed flawlessly - the brake booster setup is horribly designed yet sold for a "b" body mopar. Have a good Monday.
[Re: CDN72SE]
#911611
03/14/11 04:09 PM
03/14/11 04:09 PM
Posts: 4,108 Horsham, Pa.
Finoke
Horsham, Pa.
We're definitely still watching this thread, keep up the great work.
I've been watching too! Don't dare stop posting pictures
[Re: Finoke]
#911612
03/14/11 08:03 PM
03/14/11 08:03 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
My favorite project on here so far!!! The more pictures the better!
[Re: MuuMuu101]
#911613
03/14/11 08:56 PM
03/14/11 08:56 PM
Posts: 333 Vandergrift,PA
The70RTChallenge
Vandergrift,PA
Keep em comming!!! Don't worry you've obviously got a few of us as followers
[Re: The70RTChallenge]
#911614
03/14/11 09:47 PM
03/14/11 09:47 PM
[Re: dmaddox]
#911616
03/15/11 11:31 AM
03/15/11 11:31 AM
Posts: 1,300 Washington
19cuda73
Washington
Keep the pictures coming, your making great progess, I too enjoy seeing your build underway, the car looks great. The Blue landcuiser must be one of those side projects. Did one a few years ago with a chev 350 it.
Dennis
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: dmaddox]
#911618
03/16/11 11:02 AM
03/16/11 11:02 AM
dmaddox
your fridge
Good Morning fellas! Yesterday evening was spent in the paint booth, prepping and painting the cowling area. It sure does look sharp! The FY4 "Citron Mist Metallic" is an interesting color. In the booth under florescent light, it looks very goldish with a hint of retro-green. In the garage is looks olive green. Pretty strange and neat at the same time. At first I thought it looked like puke - but I wanted the color to match the fender tag, along with all of the decals, options, etc.. In short, if I ever wanted to put OEM wheels/tires on it, it'd be pretty close to stock (calm down you purists, I know there's a lot "off" with a correct resto, I'm just sayin') Anyhow - here are some more pictures: and one more from last night: Once I get all of the body/paint buffed and polished....I am not sure what to do next. I'll likely start under the hood. Phew....SO CLOSE yet so far away. Have a great day, dallas
[Re: dmaddox]
#911620
03/22/11 07:24 PM
03/22/11 07:24 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
man, i dig that color! great job!
unions....the folks who brought you the weekend!
[Re: 68-scatpack-rt]
#911621
03/23/11 11:35 AM
03/23/11 11:35 AM
dmaddox
your fridge
Thank you!! I can't wait to get this on the road! I also need to find someone in the greater salt lake area that has skills setting up/dialing in the front end. It's about 2-3" too low. Hood emblem in place: Letting the sun cure the paint a bit:
[Re: dmaddox]
#911622
03/23/11 11:40 AM
03/23/11 11:40 AM
The70RTChallenge
Vandergrift,PA
I see clouds
Definetly get a good look at the paint as well as the tire/wheel combo outside. Lookin good!!
[Re: 440beep]
#911624
03/27/11 02:03 PM
03/27/11 02:03 PM
dmaddox
your fridge
Gents. . . .to be honest I was going to just put a battery from wal-mart in the car. Then, I started to think about the "look" under the hood and bit the bullet: Heavy sucker! I had a little buyer's remorse with this battery, but it's the correct part, so I am trying to justify it :-) Another expense was the wiring harness - even though behind the dash was in really good shape: Looks painful in the box, but I have wired a rig before, shouldn't be too bad. Also, am affixing decals, so far, just the tail done: The trunk is actually popped so it looks "off" but in reality it is spot on: Moving along. . . have a great weekend, dallas
