Re: dmaddox's 1970 RoadRunner Restoration (first Mopar)
[Re: dmaddox]
#911565
01/25/11 12:08 PM
01/25/11 12:08 PM
Posts: 543 Indiana, Just Off I-70
BradD
Here ya go Dallas! A GENERAL guide. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: BradD]
#911566
01/26/11 06:19 PM
01/26/11 06:19 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
An amazing amount of work in restoring a car as you already know. Your work looks great. My only concern for you is that the fenders and the tail light buckets were mounted with seam sealer before painting. Front fender seams oozed out and was painted. Rear buckets were mounted and the seam sealer that oozed out was wiped leaving a seam that also was painted. There isn't anyway to reproduce that look without painting after mounting. Sorry to mention it but that the way they were done.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#911567
01/27/11 01:03 PM
01/27/11 01:03 PM
Posts: 60 your fridge
dmaddox
your fridge
I recall restoring my first land cruiser. Wrong colors here and there, incorrect year pieces, etc.. It took me a good 2-3 cruisers to be able to restore them accurately. I am even working as we speak on a 1981 BJ42, which is a diesel 40 series. Never sold in the USA. So, I have to source parts from Canada primarily as well as Australia and New Zealand. Very difficult. With that being said, I know that in many respects I am f'ing this RoadRunner up. However, I am fixing all of the bits mentioned the best I can. I'll never sell this car. Maybe even in 10-15 years I'll tear it down and do it again after I have learned more. Sometimes I regret posting projects because the negative feedback outweighs the positive. Anyhow, little by little I have removed the nuts holding the heater on as well as the wiper motor and they are now the requested anodized gold or whatever it was. Same with the shock mount tower bushings, removed, repainted the well top, and installed a new bushing. I'll do the same with the clutch boot as well as the inner fender filler pieces up front. Sorry this isn't concourse, but in my eyes it is, and I'm having fun. -dallas
[Re: MOPARMIKE69]
#911568
01/27/11 01:14 PM
01/27/11 01:14 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Judging by the wheels, the car's not going to be stock anyways...I think it looks fantastic and more importantly the project is actually moving in a forward direction... If you hang around enough, you'll find guys on here that take years to do what you've accomplished in a short time.. You might get better response if you ask details about specific parts that you WANT to learn about, that way we won't be so rough on you for the other little nick-picking things
CHECK OUT MY NEW WEB SITE !
[Re: dmaddox]
#911569
01/27/11 01:20 PM
01/27/11 01:20 PM
Posts: 4,179 California
mickm
California
-dallas
in my eyes, you are not f'ing this up in the least, you are doing it a great service! you can't expect to go into something like this the first time and know everything. if you want to do concourse, you have to be wiling to spend an insane amount of hours trying to figure out what is "correct", and even then two of the most respected sources can tell you two completely different things.
most of the people here will give you positive feedback, just because someone's writing style may come across as harsh, doesn't mean their intention is. for those that give negative feedback, well... f'k em. this is your car, to do with what you want. there are many people who do things with their cars that many others don't "approve" of, but they do it because it is their car, and that is what they want from it. done.
restore the car, learn as you go, do what you want, and it will be what you want, (and a damn nice car by the looks of things so far), and you will be happy with it.
and by all means keep on posting!
[Re: dmaddox]
#911571
01/27/11 02:38 PM
01/27/11 02:38 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
I'm having fun.
And THAT is all that matters. Don't let anybody rain on your parade. However, if you really do want to learn about restoring Mopars, I'd suggest spending some time looking around on Alan's website.
click here
[Re: dmaddox]
#911573
01/27/11 03:29 PM
01/27/11 03:29 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
......constructive criticism.
Hi Dallas! The car looks Fantastic and it appears you are having fun as the project progresses. Keep in mind that some people have about as much credibility to "criticize" you, as Ed Norton has the right to tell people how dumb they are! Keep up the great work!!
http://www.youtube.com/watch?v=ypYEYaD-duA
[Re: ECS]
#911574
01/27/11 04:37 PM
01/27/11 04:37 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Car looks great and you're doing a fabulous job. I love the color; the wheels not so much, but they're easy to change! I guess I'd say that posting resto pics on here isn't for the thin skinned! Make it known whether you want constructive criticism or not. Are your trying to make the car look semi correct and want advice or are you making a hotrod (which is fine) and prefer to do it your way. Unless you are Dave W (ECS), then your resto is just like everyone else's: an attempt to replicate a factory look.......with the exception noted some get closer than others but ALL have some detail that is less than perfect so you certainly shouldn't get discouraged. The pic someone posted previously is good info. If you are trying for a factory(ish) look, some of the common mistakes on I see on many cars are; - trunk painted wrong (usually black or splatter paint ala GM) - trunk and floor plugs not cut or installed - black engine bays - black hood hinges - no wheel well undercoating - body color inspection plates - body colored upper control arm bolts/nuts/washers - no rad support blackout - painted or incorrectly finished hood and trunk latches and springs - incorrect fasteners (lots of decent kits available to stop you from having to use hardware store variety bolts, screws, etc.) - battery trays not painted body color - master cylinders and/or boosters finished incorrectly - ugly 3spd wiper motors. - parts store rad cap - gear hose clamps - generic battery ....and of course many others but those ones stick out to me. Good luck with the build and as I said; car looks fabulous. There is a link to my Superbee resto in my signature; take a look and feel free to critique away! There are some mistakes I made before I knew better and there are some purposely done for a variety of reasons. Ultimately, there are lots of knowledgeable and helpful guys here, so when you want to know something, just ask. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: RJS]
#911575
01/27/11 05:54 PM
01/27/11 05:54 PM
Posts: 6,224 JERSEY
RJS
JERSEY
You have done exceptional work there!!! Since I see you are very talented before installing the engine correct a couple of small things in the engine compartment: Take the voltage regulator bracket off firewall along with clutch boot and that wire and the heater box and 3 nuts off wiper studs throttle cable and shock bushings and anything else that unbolts and touchup. With a car that fine you'll be happy you did it now and not later.
Hi again, since I was the first to tell you of incorrect but easily fixed items I figured I should respond:
From the look of your workmanship I pale in comparison so don't take anything I said as bad. Reread what I wrote to see I started with praise because that is what is due. I didn't want you to install the motor and then have to tape and cover stuff as your in there with a detail gun. OH and by the way I dig the wheels too!! Ron
[Re: dmaddox]
#911577
01/28/11 02:19 AM
01/28/11 02:19 AM
dmaddox
your fridge
Fellas, Another update. First, as you read in my post from earlier today I have been fixing and applying all of your recommendations that pertain to "correctness" and yes - I am trying to be correct, yet add a hot-rod flare. I blacked out the radiator support. I taped off and fixed the frame rails: Next, I used this template to mask off my hood: taped off (my buddy Clarence, who is helping me on the project): I used OEM Organosol Black: Also, let me know what you guys think on that ebay battery tray deal in my last post. G'night dallas Looking good?
[Re: CDN72SE]
#911580
01/28/11 12:32 PM
01/28/11 12:32 PM
Posts: 1,183 eganville ont
440beep
eganville ont
go here i look roadrunner nest.com at the 71 gtx pics blackout behind the grill was replicated from what the cars original blackout looked like. Its not all black, its the same way as my '71 GTX. I dont know about 1970, but mine is the exact same way before I painted it. Finally Paint! (Updated 12/20/10) for the pics
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: dmaddox]
#911581
01/28/11 12:45 PM
01/28/11 12:45 PM
Posts: 2,106 New Mexico
JMCFAN
New Mexico
Where did you get the orginsal paint?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: RJS]
#911583
01/28/11 01:01 PM
01/28/11 01:01 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Good job.. Love the color and pictures of the sheetmetal repair..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
