slant 6 distributor from points to convert??? #91142
07/20/08 01:53 AM
07/20/08 01:53 AM
Seattle/Tacoma ,Wa.
340man Offline OP
340man  Offline OP
Seattle/Tacoma ,Wa.
I was wondering if there is anyway to get away from using points on my 71 dart with a slant 6 motor??? Any help out there?? Scott
Re: slant 6 distributor from points to convert??? [Re: 340man] #91143
07/20/08 01:56 AM
07/20/08 01:56 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There are several ways. One of the simplist is to use the Pertronix set-up. I have one in mine and is works fine. It sure helped a lot. Other ways include the Mopar electronic conversion and an HEI conversion. Check out the Slant Six Forums for some additional insight.
Re: slant 6 distributor from points to convert??? [Re: jbc426] #91144
07/20/08 02:00 AM
07/20/08 02:00 AM
those points sure are a pain to get to on those /6's
Re: slant 6 distributor from points to convert??? [Re: RapidRobert] #91145
07/20/08 02:08 AM
07/20/08 02:08 AM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
Pertonix is good.
The best slant site is www.slantsix.org
The guys there can give you other options
Re: slant 6 distributor from points to convert??? [Re: noisydart] #91146
07/20/08 07:05 AM
07/20/08 07:05 AM
Farther south than I was befor...
ChrisH Offline
ChrisH  Offline
One more vote for pertronix. 1/2 hour to install and about 70 bucks to your door!
Re: slant 6 distributor from points to convert??? [Re: ChrisH] #91147
07/20/08 08:37 AM
07/20/08 08:37 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
If you use the pertronix set-up with your original distibuter you won't have to recurve the junkyard electronic.
Re: slant 6 distributor from points to convert??? [Re: convx4] #91148
07/20/08 12:19 PM
07/20/08 12:19 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I still run points. I have spun my slant to 5900 no problem!
I will be switching to GM HEI or Mopar in the future.
No Pertronics for me. To many horror stories, and I drive my car long distances.
I need cheap parts off the shelf in every state I visit.
Either that buy 2 Pertronics, and test drive both. Keep one for a spare.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: slant 6 distributor from points to convert??? [Re: 340man] #91149
07/20/08 03:58 PM
07/20/08 03:58 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Another vote for pertronix.Had mine on the dart /6 for two years..no problems at all.I used their recomended coil on my conversion also.If pertronix guidelines are followed,their stuff is pretty much problem free,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
