SB Eddy heads 48*?
#908323
01/18/11 09:16 PM
01/18/11 09:16 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
since I purchased the new 48* block got to thinking if Eddy heads can be made to work at the new angle without too much trouble?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: SB Eddy heads 48*?
[Re: Stroker Scamp]
#908324
01/18/11 09:20 PM
01/18/11 09:20 PM
Triple Threat
Renton Washington
I know the Indy's can, edelbrocks shouldn't be too terribly different. Just clearance the pushrod holes and run somewhere in the neighborhood of a 1.65 rocker arm.
[Re: fishy340]
#908326
01/18/11 10:36 PM
01/18/11 10:36 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
indy's to eddies is like rosie o'donnell to angelina jolie..don't do that bro..
LOL good one
[Re: fishy340]
#908327
01/18/11 11:06 PM
01/18/11 11:06 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Case closed.
[Re: Stroker Scamp]
#908331
01/19/11 01:09 AM
01/19/11 01:09 AM
Posts: 6,148 Melbourne , Australia
LA360
You have to re-machine the pushrod holes, they will cut through the gasket face. Some clearancing may also be required of the manifold. The W2 AB heads had this. The 48 degree Indy heads have additional material on the gasket face and the different pushrod holes. It might be best to sell the Edelbrocks now, and upgrade, as it might be harder to sell them once you have modded them for the 48 degree block.
I am sure Ryan will chime in with more info.
Alan Jones
