Re: Whats The Go Fast Electric Fan
[Re: Sport440]
#908043
01/18/11 08:27 PM
01/18/11 08:27 PM
gtx69
super gas
super gas
30-13 was correct for hhr fan.Taurus fan i didn't measure myself was told that by someone else.I couldn't fit the Taurus fan on my can so i didn't measure it myself .But since this i have switched to a different fan.
[Re: gtx69]
#908044
01/18/11 09:08 PM
01/18/11 09:08 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Taurus fan pull more amps than hhr fan.,It is also thicker.I know you will need a lot of alternator for the taurus fan.Check the amps for the taurus.
I run the Taurus fan...and it's a great fan. But he's right...it pulls way more amps both at startup and while running. No telling if it actually pulls more air (the 4000cfm) like people claim though. I run a 140 amp powermaster alt...so it doesn't bother me.
The Taurus fan may be thicker...but it likely can fit where the HHR won't because its motor is offset in the shroud allowing the waterpump pulley to clear the fan in my car. The HHR wont fit my car with a mech water pump...but it would clear with an electric Water pump.
I would run the HHR fan if I could just because it would fit my northern radiator almost perfectly.
[Re: gtx69]
#908045
01/18/11 09:15 PM
01/18/11 09:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that the Taurus fan assm is thicker(the whole thing) I probably cant use that... I'm working with some small area for the radiator and fan ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Sport440]
#908048
01/18/11 10:25 PM
01/18/11 10:25 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
depends on the size of your rad the HHR fan was to small for my rad so I found 1 from a 95 caravan that works great and covered my entire rad.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: BBR]
#908052
01/18/11 10:59 PM
01/18/11 10:59 PM
MR_P_BODY
And lucky for you I just got a RockAuto discount code in my email:
27638392284705
I think it's 5%, but hey, it's better than nothing!
Well I just ordered the HHR fan and used that 5% discount.... thanks ![](/ubbthreads/images/graemlins/wave.gif)
