Re: building 360, need cam advice
[Re: west]
#906790
01/17/11 05:15 PM
01/17/11 05:15 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
#3400 kb's 9:1 xe284 and eddy heads,rest of block is stock air gap,headers,700 cfm,converter and 3:73's does low 12's on street tires all day long. shootin for 11's but prob won't get there without spending more money.
Shouldn't be too tough tapping into the 11's. Been there. 4:30 gear, slicks, LD340 intake unported heads with 1.88 valves. 271 hdp crower cam ran me 11.70's all day Hughes cam and heads put me in the 11.40's.
[Re: GO_Fish]
#906791
01/21/11 09:12 PM
01/21/11 09:12 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Slow down and do more research before dropping your $$$ down. You don't want to go off "half cocked", then be very unhappy with the results and $$$ down the drain.
No sense in 2.02 valves on the street usually. If it is usually running 4500 rpm or less, 1.88 valves will be fine. Save your money for elsewhere. Don't say what trans you are running. If automatic, you will be much better spending money on a better converter than on big valves.
If you rush and throw something together half arsed, you will be wasting money and leaving performance on the table.
Carefully, patiently, get a plan together, then you will be happy with the results.
And he IS running a 4-speed, so the bigger valves would work.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
