Page 9 of 10 1 2 7 8 9 10
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905415
10/05/11 11:39 AM
10/05/11 11:39 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It would definitely save you on the clutch changes you will be doing ...
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: JohnRR] #905416
10/05/11 04:46 PM
10/05/11 04:46 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Yeah,
the 440 six pack did a job on the 10.5" McLeod disc on its own and it is 350 hp less.
I am thinking about getting that $899 dual disk McLeod setup if I choose to keep the 4 speed.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905417
10/21/11 12:02 AM
10/21/11 12:02 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Sorry folks!!
I was convinced to go with the full manual auto. I traded the 4 speed for the 727 with a bolt in sprag, reverse manual valvebody, red kevlar clutches and a 2800 stall. I know the 4 speed would have been a blast on the street but I have a few friends with their mid to high 6 second 8th S10's and Luv trucks that need their asses cracked by my streetcar!
I still think it will be just as much fun with the auto!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905418
11/19/11 09:24 PM
11/19/11 09:24 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Well,
I am waiting on the 727 so I got the body in epoxy sealer and started cleaning up the dash. Got it painted black and detailed the cluster bezel. Shot it with Mirrachrome paint and detailed the black and silver areas. Also polished the lenses. Looks good for now. I need to find a better bezel and spend a bit more time on it since this one had alot of dings, nicks, scratches and cracks. I also used the Whitegauges.com whiteface decals and the blue l.e.d.'s. I also managed to get a Phantom tach in the stock location. Looks pretty good if I may say!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905419
11/19/11 09:26 PM
11/19/11 09:26 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Blue L.E.D.'s
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905420
11/19/11 09:29 PM
11/19/11 09:29 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Mirrachrome sprayed
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905421
11/19/11 09:31 PM
11/19/11 09:31 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Detailed
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905422
11/19/11 09:35 PM
11/19/11 09:35 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Completed
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905423
11/19/11 09:38 PM
11/19/11 09:38 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Body before
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905424
11/19/11 09:39 PM
11/19/11 09:39 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Body after
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905425
11/19/11 09:42 PM
11/19/11 09:42 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Body 2
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905426
12/04/11 07:40 PM
12/04/11 07:40 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Just about got the body ready for paint. Working on the doors and still need to get to the fenders. May get it painted here in a few weeks. Trans should be here this week. Then I can get it started!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905427
03/21/12 03:30 AM
03/21/12 03:30 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Its alive!! Haven't hooked the piping up for the turbo yet. Had some issues with the MSD BTM. Got that figured out finally. Waiting on a few more small parts before I start tuning. The lowdeck sounds really good just running through the carb.! Scott Brown cam has quick crisp throttle response and nice idle. Can't wait to get this thing rolling.
This thing is going to be a beast!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905428
03/21/12 03:33 AM
03/21/12 03:33 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Dash,
trying to locate a bulb socket for the light near the alternator gauge so it looks a little dim there. Also made a pod for the two gauges on the column. Turned out nice.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905429
03/21/12 03:41 AM
03/21/12 03:41 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Body is in final prime and doors, glass installed. Working on the front clip too.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905430
03/21/12 03:49 AM
03/21/12 03:49 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Here is the pod I made from 2" pvc
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905431
03/21/12 03:56 AM
03/21/12 03:56 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
1 more of the pod
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905432
04/20/12 01:21 AM
04/20/12 01:21 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Got a few Gremlins to get rid of but its alive carb'd.. Got the exhaust to where the header collectors would be. Will work on the mufflers soon. Here is a short vid,
http://youtu.be/mKrLtfG2qic
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905433
04/20/12 01:47 PM
04/20/12 01:47 PM
Texas
racer_amx Offline
racer_amx  Offline
Texas
Sick, love the sound of a big block with turbos
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: racer_amx] #905434
04/20/12 01:52 PM
04/20/12 01:52 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Nice, that's an awesome build!
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
