Re: 68 383 Formula S now 411" B with Borg/Warner S480
[Re: CUUDAK]
#905276
01/25/11 11:17 AM
01/25/11 11:17 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My turbos hang off the headers. No doubt that's part of the problem.
[Re: CUUDAK]
#905279
01/26/11 09:47 PM
01/26/11 09:47 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Started the driverside log, still gotta cut the top angle. My dumbass cut the 90's pointing down the first time .. That why the ends are butchered but they will be cut at a 45.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: CUUDAK]
#905282
01/29/11 12:04 AM
01/29/11 12:04 AM
CUUDAK
HEMPSTEAD TX
Well, got the driverside log done. This Aluminized piping is a PITA to weld even after grinding the coating :bang:... Will dress these welds and run a wide pass to confirm seal. O'well, looks like it will be usable!
[Re: CW25]
#905286
01/29/11 09:51 PM
01/29/11 09:51 PM
CUUDAK
HEMPSTEAD TX
Thanks CW25...
Started the crossover pipe. Looks good and no interference as of yet.. Again, this will all be wrapped. The front valance should cover half of the crossover view from the front. I like the "No bumper" look on the front enuff to leave it off.
[Re: CUUDAK]
#905292
01/30/11 06:06 PM
01/30/11 06:06 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Very cool & your build has me thinking of changing my desire to procharge my 68 383 formula S, to twin turbo. But I'm concerned about the high underhood temps the turbo generates. How do you prevent the extreme heat from cracking your hood paint, since its so close to the hood? The turbo on my 99 Eclipse GST gets pretty hot, but its location isn't so close to the hood as yours. I like the idea of a turbo producing max torque sooner in the rev band & getting better mileage than the procharger.
All the hotside piping will be coated with VHT and then wrapped with DEI kevlar header wrap with a good coat of their black spray silicone. I will only wrap the first 2 feet of the 5" DP just to keep those temps out too. You thinking twins, go over to FABO's site and and look at MadDart's twin turbo Dart build. He's done a great job with the attention to detail. LONG read though but thorough!! Going twins will make it easy for the hotside since all you need is a log style like the driverside on my setup for both on yours. I thought about twins but that was twice the price and I am on a "Strict" budget.
I will also add the hood insulation to protect the paint.
Thanks for the info & I'll check out maddart's post. know Ceramic coating & thermal barrier coating really reduces temps & when I had Ram Proline do my hemi's exhaust, it cooled the underside of my chally pretty well. I'll also friction coat the piston skirts & maybe thermal coat the tops & chambers, as I hear that really reduces detonation. Thanks for the great info. Buzz.
