Page 3 of 10 1 2 3 4 5 9 10
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905295
01/31/11 02:17 PM
01/31/11 02:17 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I've got 3.15/50 x 15 ET Streets for the back & they're pretty tall, so maybe the 3.55's will be close to 3.23's. I may have to narrow a Dana I have to handle the torque, but will try the 8 3/4 first. Thanks for the info & glad heat won't be an issue.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: Triggerfish] #905296
01/31/11 03:03 PM
01/31/11 03:03 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Get one of these and you should be fine,
http://cgi.ebay.com/ebaymotors/Demolitio...=item41565f39a3
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905297
01/31/11 07:35 PM
01/31/11 07:35 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Pistons showed up today! Still no ETA on the Eagle rods.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905298
02/01/11 12:12 PM
02/01/11 12:12 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Make sure you massage those valve reliefs and lay down and sharp edges!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: TheOtherDodge] #905299
02/01/11 02:23 PM
02/01/11 02:23 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Yep,
also coating the tops with VHT and friction reducer on the skirts.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905300
02/05/11 10:09 PM
02/05/11 10:09 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Got the brackets on the car already. My pops home built "Carl-TRAKS" are done and ready to install. He laughed cuz I put the name in Chrome
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905301
02/08/11 10:59 PM
02/08/11 10:59 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Wow what a cluster!!!
Got most of the right side done. Coatings Suck!! A Royal "PITA".... I suppose it will work. Next time I'll get a Hemi and I won't have to worry about spark plugs
Guess I'll take the hotside to my buddies and wash those welds with a TIG and get them blasted. I have VHT in flat black then they will be wrapped as stated before.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905302
02/08/11 11:02 PM
02/08/11 11:02 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905303
02/08/11 11:05 PM
02/08/11 11:05 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905304
02/08/11 11:06 PM
02/08/11 11:06 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
8
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905305
02/08/11 11:09 PM
02/08/11 11:09 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
9
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905306
02/11/11 09:03 PM
02/11/11 09:03 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
1 pipe left to do for the crossover pipe and the hotside is done :bang:. What a nightmare! At least its nicely packaged without alot of clutter. Now I can start fabbing the Intercooler bracket. Its gotta support the center hood support as well. The cold side is gonna need some welding, I don't have a tig :doh:.. Gonna have to pay for that.
Here are a few pics of the setup in place,
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905307
02/11/11 09:04 PM
02/11/11 09:04 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
10
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905308
02/11/11 09:06 PM
02/11/11 09:06 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
11
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905309
02/11/11 09:10 PM
02/11/11 09:10 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
12
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905310
02/11/11 09:16 PM
02/11/11 09:16 PM
mid-mich
turboplymouth Offline
mid-mich
Coming along nice. What aircleaner is that? I need a shorter one, that looks like it will work.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905311
02/11/11 10:44 PM
02/11/11 10:44 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Must stop looking......Man I wanna go turbo so bad on my car. That barracuda is coming out nice
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905312
02/11/11 10:56 PM
02/11/11 10:56 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Its a K&N as you probably know. I will go out to the shop afterwhile and get the Part# for ya. I has the 5" opening. I have no idea what the flow rate is tho! Cost me $40 shipped from e-&ay.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905313
02/11/11 11:45 PM
02/11/11 11:45 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
K&N Part# RU-5109
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905314
02/12/11 07:24 AM
02/12/11 07:24 AM
mid-mich
mid-mich
Awesome. Thanks!
