Re: Oliver Rods.. [Re: HPMike] #904809
01/15/11 02:41 PM
01/15/11 02:41 PM
Houston, TX
rick55 Offline
rick55  Offline
Houston, TX
Oliver rods are made in Grand Rapids, MI. Several years ago they went through some tough times, had to terminate most of their workforce, my brother-in-law was one of them. They then went through a change of ownership as well. All their production was performed by management for a period.
All this aside, Oliver rods would still be my choice for a high HP engine.
Re: Oliver Rods.. [Re: Mike Swann] #904810
01/15/11 06:00 PM
01/15/11 06:00 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I was talking to a machinist in the Tampa Bay area and he had three engines waiting on Oliver to fix the rods. He said the caps just fall off when the bolts are loosened. He said they used to be so tight that they were difficult to get off installed. It sounded like the dowels fit loose in the caps. These were for BB Cheebies. If the caps have any clearance, it seems like they will move around under load. Anyone else have this problem?
Thats a sign of detonation, over revving or the piston hitting the head.
These were brand new rods that the customers bought in a stroker package like most of would do. They were sitting there in the bags that they came in. You don't have to believe me at all. I have him checking some new Manley Hemi I-beam rods for me. Everytime I stop in to talk to this guy, I learn something new. He only does things his way and always has good reasons for everything. He builds a lot of top notch circle track engines and he won't even tell me the guy he has make his rods. He won't tell me everything he knows. It might take a while if he would, but I'd make the time. His stuff is way out of my league, but sweet stuff if you had a chance to see it.
Floyd Lippencott IV
Re: Oliver Rods.. [Re: mr_340] #904811
01/15/11 06:59 PM
01/15/11 06:59 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
I have Oliver's in one motor, Carrillo's in another. No problems with either.
Carrillo's cost 2-3 times what Oliver's can be had for.
Re: Oliver Rods.. [Re: Quicktree] #904812
01/15/11 07:50 PM
01/15/11 07:50 PM
QLD Australia
Keith Black® Offline
QLD Australia
well I will take my chances with Oliver rods over most of the junk out there.
I'll be running them in my engine, which is a 1,500~hp build.
Darren Beale
Keith Black Racing Engines®
Re: Oliver Rods.. [Re: Keith Black®] #904813
01/15/11 08:36 PM
01/15/11 08:36 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Tesar liked them. They literally had racks, of V/6 ASA engines that used them. Good enough for me. Alternate choice was Crower.(Looong lead time)
Re: Oliver Rods.. [Re: Cab_Burge] #904814
01/15/11 11:11 PM
01/15/11 11:11 PM
mi
dirty magnum Offline
mi
dont post something like that, no way is it true .. tell your buddy to learn how to use a stretch gauge.. oliver is the best steel rod ..
Oliver doesn't(or didn't several years back) recommend using a rod bolt stretch gauge to tighten thier rod bolts, they wanted you to use the torque plus so many degrees method I bought s set of their steel billet rods for a blown street Hemi project, some of the rod bolts where one length and some where another, .003 differences I called them and ask about that and they said no big deal, that happens all the time One of the rod caps wasn't machine correctly for the bearing tang, they did pay to have it overnighted Fed Ex back to them and then fed Ex overnighted it back to me I would have prefered that they caught that mistake at thier faciltity instead of letting it slip through thier quality(or lack of quality control) control My opinon is Carillos are better, Olivers are not the best steel rod, or aluminum rod company out there now or in the past 1 bad rod out of a set of 8 equals 12.5 % failure rate Not acceptable in my book
its foot lbs then torque by yield ... but a good engine builder dosent just rely on that, they measure the bolts and check the stretch ...thats why oliver gives you a stretch spec, and log book is a good idea for freshing up the motor
Re: Oliver Rods.. [Re: dirty magnum] #904815
01/15/11 11:22 PM
01/15/11 11:22 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
I have never used them,but the people that i know that have used them
there rods have windowed a few blocks!...just telling it the way it is!
Re: Oliver Rods.. [Re: old yeller] #904816
01/16/11 12:52 AM
01/16/11 12:52 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Another reason to run aluminum rods.
Re: Oliver Rods.. [Re: dirty magnum] #904817
01/16/11 03:00 AM
01/16/11 03:00 AM
Oliver doesn't(or didn't several years back) recommend using a rod bolt stretch gauge to tighten thier rod bolts, they wanted you to use the torque plus so many degrees method I bought s set of their steel billet rods for a blown street Hemi project, some of the rod bolts where one length and some where another, .003 differences I called them and ask about that and they said no big deal, that happens all the time One of the rod caps wasn't machine correctly for the bearing tang, they did pay to have it overnighted Fed Ex back to them and then Fed Ex by overnight back to me for no charges I would have prefered that they caught that mistake at thier faciltity instead of letting it slip through thier quality(or lack of quality control) control My opinon is Carillos are better, Olivers are not the best steel rod, or aluminum rod company out there now or in the past 1 bad rod out of a set of 8 equals 12.5 % failure rate Not acceptable in my book
I did measure the rod bolts, that is how I found that the bolts where .003 differences in length I ended up calling ARP and ask them which method they preffered me to use on thier bolts( Those rods had ARP 2000 bolts)They said to stretch them to .0057 to .0063 That ended up using 63 to 65 ft.lbs on the shorter ones and 75 to 78 Ft. lbs on the longer ones For the price of the rods and that companys reputation I expected all the rod bolts to be out of the same batch, (same lengths, same heat treat batch and so on) wouldn't you I thought I was going to get perfectly machined rods on all surfaces, not one rod cap that wasn't maybe that is why some motors blow up with Oliver rods and some don't
Re: Oliver Rods.. [Re: Hot 340] #904818
01/16/11 10:37 AM
01/16/11 10:37 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
My experience goes back a few years. Oliver makes a good, moderate priced rod and is fine for a moderate HP SB---up to the 700HP range and 8500RPM. Over that, I would use either Carillo or Lentz. For some reason, I just like the Lentz rod. No real reason, just personal opinion.
In the past 15 years, we have used 2 sets of Olivers, 6 sets of Carillo and two sets of Lentz. We have never, never had a rod failure. Just be careful of used rods----remember, there is a reason they are used.
Re: Oliver Rods.. [Re: 40ford] #904819
01/16/11 06:44 PM
01/16/11 06:44 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
...In the past 15 years, we have used 2 sets of Olivers, 6 sets of Carillo and two sets of Lentz. We have never, never had a rod failure. Just be careful of used rods----remember, there is a reason they are used.
You bring up a good point. there are many used NASCAR rods on ebay, Craigslist that are likely not suitable for a drag motor. Those are the taped beam rods like this example:
http://cgi.ebay.com/ebaymotors/NASCAR-CA...sQ5fAccessories
What you want for drag motors are the non-tapered rods like this example:
http://cgi.ebay.com/ebaymotors/CARRILLO-...sQ5fAccessories
Re: Oliver Rods.. [Re: Cab_Burge] #904820
01/17/11 12:34 AM
01/17/11 12:34 AM
mi
mi
i agree if they were that bad i would have sent them back , ive never run into a set like that , another good point is there is forged olivers rods and billit olivers forged are alot cheaper$ , i always use the billit they have a wsb bolt witch is semilar to a L-19 or a carr bolt way better quality.
Re: Oliver Rods.. [Re: old yeller] #904821
01/17/11 08:45 AM
01/17/11 08:45 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
very informative, connecting rods that have failed. please list all the manufactures of connecting rods that have never experienced a failure.
Re: Oliver Rods.. [Re: jamesc] #904822
01/17/11 10:36 AM
01/17/11 10:36 AM
North Carolina
K
keelsracing Offline
keelsracing  Offline
K
North Carolina
The only ones that I know of are the ones that have NEVER sold any rods to any one
I do understand the original post and the meaning but these parts are going in RACECARS S*&T happens and you should be aware that it may happen to you... just saying, not looking to make anyone feel singled out or trying to insult anyone.
Re: Oliver Rods.. [Re: dirty magnum] #904823
01/17/11 12:58 PM
01/17/11 12:58 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
This is like any part you can buy. But if you compaire say eagle SIRs rep with Olivers, yes both have had issues, but who has them more often. We had Olivers in our 588, it was a HOG, and got ran hard. Good pieces, but every part bought for any racing application is only as good as the machinist, or guy putting the parts together. If there is a part that went through and has issues, and it was cought before assembly then that shows 2 things, 1 SH!T definatly happends and passes buy QC, and 2 The person doing the assembly was great for catching it.
Take the 501 small block build for example, top notch rods were custom ordered and they too had a fault. Now is that something that happens all the time, I doubt it, was it bad for their reputation, Well on Moparts for sure, is their company a good company, sure or they wouldnt be in the business.
If I was going to build a top notch engine, Id run them. Hell If I was going to build my build over again they would be in there if I could aford them.
Im running Childs track masters now, they checked out great when I got them, and litterally nothing was needed machine wise to make them a go in my build. Now on my cheapo 360 I built I used Eagle SIRs before I knew better, and after all the BS to make them a go I would have been money ahead to get a set of H beams, or a set of scat I beams, but I didnt know they were going to need resizing before runing them.
I know now, and I always check over anything I install in any engine no matter what the reputation of the part, and how spendy it is.
Its just a good habit to get into.
Kasey
Re: Oliver Rods.. [Re: Hot 340] #904824
01/17/11 02:02 PM
01/17/11 02:02 PM
an8sec70cuda Offline
I have Oliver rods in my hemi and they were perfect right out of the box. Been beating the snot out of em for over 4 years w/ no problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Oliver Rods.. [Re: 40ford] #904825
01/17/11 04:16 PM
01/17/11 04:16 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Oliver makes a good, moderate priced rod and is fine for a moderate HP SB---up to the 700HP range and 8500RPM. Over that, I would use either Carillo or Lentz. .
......better not let Nelson Racing Engines know about that. they run Oliver steel rods in there Twin Turbo 632 crate motors makeing 2200hp. just sayin.
Re: Oliver Rods.. [Re: Randy..] #904826
01/17/11 05:07 PM
01/17/11 05:07 PM
Delray beach, Florida
P
Performance Only Offline
P
bottom line is that this is still the internet and your going to get all sorts of "opinions" and "thoughts". some from people that know what they're talking about and plenty more from people that not only don't know, but who have no first hand experience with the product.
as i said before, we've sold and used Oliver rods for many years now and i've yet to ever have a single issue, for whatever that's worth.
machine shop owner and engine builder
Re: Oliver Rods.. [Re: Performance Only] #904827
01/17/11 05:20 PM
01/17/11 05:20 PM
Moparnut426 Offline
Moparnut426  Offline
Well Said!!
Kasey
Re: Oliver Rods.. [Re: Performance Only] #904828
01/18/11 02:42 AM
01/18/11 02:42 AM
mi
mi
^x2
