Re: Edelbrock Performer intake coil mount ??? [Re: Junky] #904356
01/15/11 07:30 PM
01/15/11 07:30 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I dont want a coil wire running to the fender or the firewall.
Neither do I. I will make it work. I also have the MSD Leaker2 coil. I gotta get rid of that thing. Is there a good, leak free alternative that mounts in a stock type bracket?
MSD has an epoxy filled blaster coil that looks just like the oil filled ones.
Yep, it's the high vibration coil...You need that one if you use any horizontal brackets...
Re: Edelbrock Performer intake coil mount ??? [Re: scratchnfotraction] #904357
01/15/11 07:46 PM
01/15/11 07:46 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Yes a small block coil bracket works. On mine i used a peice of tubing from an alternator bracket and cut it to make a spacer to use the big block coil mount.
Re: Edelbrock Performer intake coil mount ??? [Re: sam64] #904358
01/15/11 07:50 PM
01/15/11 07:50 PM
Dougsmopars Offline
Dougsmopars  Offline
It's on right. EGR plate is on drivers side on the RPM intake
Re: Edelbrock Performer intake coil mount ??? [Re: 64B Body] #904359
01/15/11 08:08 PM
01/15/11 08:08 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
I agree with sam i believe you have it on backwards
I don't think it's on backwards.
Scott
1969 Super Bee, 383/4 speed
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904360
01/16/11 09:41 PM
01/16/11 09:41 PM
Northern NJ
Northern NJ
I wound up ordering the "coil bracket single bolt vertical mount" adaptor from Hughes Engines. It was cheaper than buying a new coil.
http://www.hughesengines.com/Index/produ...mp;partid=25486
Scott
Re: Edelbrock Performer intake coil mount ??? [Re: StukaJU87] #904361
01/17/11 12:09 AM
01/17/11 12:09 AM
scratchnfotraction Offline
see..thats better than any ferd part you could have found
