Re: Car. IRL rods in a small block.?
[Re: quick77rt ]
#903369
01/13/11 04:50 AM
01/13/11 04:50 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Depends on intended horsepower and rpm. What are the goals of this fantasy build?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: DemonDust]
#903372
01/13/11 01:26 PM
01/13/11 01:26 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Those motors have extremly short strokes but the bores are about the same as our SB motors. The pistons are way lighter than anything we ever dream of useing also. Exact strokes and bob weights are gonnna be top secret but if you could find them you could calculate how much load they would see. Just off the top of my head I would figure they are gonna have about 1/2 your stroke and an off the shelf piston for your motor is gonna weight twice what the IRL piston weighs so it would be more stress at the same HP. Now if you are talking about a NASCAR rod with IRL journals, they are desighned a little different.
[Re: HotRodDave]
#903373
01/13/11 01:35 PM
01/13/11 01:35 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I'm pretty sure he's talking nascar carrillo rods with the IRL journal (1.850)....
At least that's what I based my previous post on ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: quick77rt ]
#903376
01/13/11 03:11 PM
01/13/11 03:11 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Yes, it could work OK. If you lower the rpms with the same ratio as you increase the stroke, + some margin, and use a heavier damper, it could work OK. I also like different! Just ground my old Mopar 3,75 LA crank to accept 2,1" SBC 6,2" rods, for an R3 9,1" alu block, with 2. hand 4.130" 1,062 C/H pistons; cheap fun!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Oyvind Mopar]
#903377
01/13/11 04:06 PM
01/13/11 04:06 PM
Posts: 288 IL. Jerseyville
jg309
IL. Jerseyville
if inrested i've got aset of 6.2 carrillo rods w/ 1.88 pin size w/.940 width & .780 rist pin size, these have have the ar800 3/8 bolts, edm oiling, $350 +freight jg309@hotmail.com, 618-806-1564 thanks
[Re: theclutcher]
#903383
01/14/11 01:26 AM
01/14/11 01:26 AM
DemonDust
Menomonee Falls
The newer nascar stuff is in the 1440-1480 range.
The older 2.000 stuff is any where from 1700-low 1800....
My engine has a 1467 bob weight
There are also a few in between there as well.
So to be safe nascar stuff can be from low 1400- low 1800.....
[Re: DemonDust]
#903384
01/14/11 01:45 AM
01/14/11 01:45 AM
Posts: 2,172 Ohio
theclutcher
Ohio
makes you wonder just how low you could go with alum rods instead of steel... but thats another thread.
[Re: DemonDust]
#903385
01/14/11 01:55 AM
01/14/11 01:55 AM
quick77rt
Parts Problem
Parts Problem
IIRC it was in the 1600-s I really dind want to toss a low number out because if was wrong/unrealistic I didnt need 40 posts tellimg me so. The dude that did its a member here, maybe he will share that combo I refered to. I really like RPM, and turn strokers past what most do and ive a good many parts that would make this a solid build..... All the rod sets have the small pin which is edm oiled, I imagine some high end pins would be in order, and wouldnt a 6 inch rod and small pin keep things way off the rings???? One the pin note, when I put together the hughes 426 kit, the ad said small dia lighweight pins...both std pins (what ross uses) and the smaller pin were dead on on the gram scale...which really means nothing. Id like to do this with an X block base and the nice B1BA heads I got from Kas. And im thinking with the heads maxed out I can have a good solid build but at the same time the heads will keep me limited to a certain power level within specs as not to over run the rest of the parts. I really want to run a std 250 shot so maybe some gas ported, small pin pistons. Again, thanks for the input....and if anyone has firsthand info on this idea....please stepup, good or bad....id rather hear hey stupid it wont work that way vs, id look at this area, as I may not look and it might cost me money. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dos Snails]
#903387
01/14/11 12:59 PM
01/14/11 12:59 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
The only problem I can think of is a relatively small bearing surface for a power adder
Speeking of small bearing surface, Have ya ever seen a 5.4 or 4.6 or ford v10 they have one of the narrowest bearing of any engine I have ever built, and I know some 4.6 muskrats have 300 shots to them all the time. I thing if they are oiled properly, and the engine is prepped for the abuse the bearings should be fine.
Justmy . ![](/ubbthreads/images/graemlins/shruggy.gif)
Kasey
