Re: building back half car
[Re: Chargerfan68]
#903252
02/05/11 02:33 AM
02/05/11 02:33 AM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
I just ran across some pictures of a '63 with a 4 link backhalf. The frame connectors were put in wider and straight as suggested above and then a triangular boxed support was welded in to the 4 link bracket location.
This is what I will do. Any problems forseen doing it this way??
Thanks, Greg.
[Re: Chargerfan68]
#903253
02/05/11 03:01 AM
02/05/11 03:01 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
The rear frame rails come forwards and down to the 4 link cross member at your determined width { 26" ] , the brackets for the 4 link are welded to the frame rails/crossmember, the forward frame rails can be welded anywhere on that crossmember and do not have to be inline with the 4 link. You still have to anchor the 4 link crossmember to the body. When I back halfed mine, I welded short 2x3 tubing to the remaining spring frame location and inside rocker area , then welded the rear frame rails to that. My frame connectors are welded into my original frame ,a short piece , which remained, my ladder bar crossmember is welded to my frame connectors which comes straight back from the front frame.
[Re: rowin4]
#903254
02/05/11 08:36 AM
02/05/11 08:36 AM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
On our 68 charger we orginally had the bars going to outside of the torsion bars to allow removal. Once we went with a strut we had to anglecut the front snot to fit against the connectors. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Chargerfan68]
#903258
02/05/11 02:50 PM
02/05/11 02:50 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Hey guys,
Well I am getting close to installing the back half kit. It is arriving tomorrow and I am finishing up the repair and reinforcement of the rocker area. This is after cutting the back of the car off and removing the rusted and damaged rocker area. Thanks for any input, Greg.
OH, DEAR, Lord help us!!! You are a far, far braver man than I am!!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Chargerfan68]
#903260
02/05/11 05:51 PM
02/05/11 05:51 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Hey guys,
Now, a few more questions. I went with the Chris Alston ChassisWorks Eliminator II 4 link setup. When I looked at the specs, I was surprised to see that it is designed to set the rockers at 6" off the ground. Is this correct?? It just seems so low and the front of the car at the rockers is about 8" with the drag torsion bars . I have them cranked up pretty high for some built in stored energy and the front control arm (lower) are still just touching the bump stops. I can't really set the front any lower.
At 6 " up front, the header pipes would almost be scraping the floor.
So the first question again is : is this right based on your experience with this particular kit?
If this is not right and potentially a problem, I was thinking of cutting the front section of framerail at the downleg of the rail 2 ", which would raise the car height 2" , giving me rockers at 8". If I do this, I know the 4 link brackets would hang down 2 " lower, and I would reinforce the front area of the brackets back into the frame connector area , and get shock/spring height 2" longer to make up for the height change. This would leave the bracket geometry the same as before and just be lifting the car up 2".
Is this correct and do you see any problems with this?
Do you plan on getting the rear quarters, tail panel and such mounted before handing the rear frame rails? IMO that stuff needs to all be in place so the rear end and wheels can be correctly located. Need reference points to work from...not to mention something to plumb and square things to. Me, I would have left that stuff in place, cut the floor out only, hung the frame rails to the rear bumper support, then thought about changing quarters, sheet metal, etc.
[Re: Sixpak]
#903261
02/05/11 07:38 PM
02/05/11 07:38 PM
[Re: Sixpak]
#903262
02/06/11 02:49 AM
02/06/11 02:49 AM
Chargerfan68
New York, USA
Thanks for all the reference materials and info guys...I appreciate all of it. I do have all the sheetmetal and it will be in place (mocked up) when I fit the frame rails in. I also have very careful measurments marked on the floor of all the relevant points. My goal is to go slow and very accurate. I am just finishing the rebuilding of the rear portion of the rockers and I went with 16 ga which is thicker than the factory. I am also using 1/8" plates at all the crossmember locations to add strength. It was far easier to cut off the entire clip than remove the trunk and frame rails without the qtrs. I will post more pictures as soon as I can upload them on here (probably tomorrow eve.) Greg.
[Re: Chargerfan68]
#903263
02/06/11 03:56 AM
02/06/11 03:56 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Thanks, Greg.
That is exactly what I was going to suggest. Beep
[Re: cbarracuda]
#903266
02/08/11 01:36 AM
02/08/11 01:36 AM
Chargerfan68
New York, USA
Nice work Cbarra. Looks great so far. I just finished repairing and reinforcing the rear part of the rockers and I am ready to start working on the front crossmember for the 4link. I am planning on using some 1/8" plates to weld to my new rocker area and then weld the xmember to those plates. Any problem with certification if I just use maybe a 4X6 plate instead of a 6X6 contours to the rocker? It would be easier to just use a flat plate and it is still (I think) above what is required...which is to just weld the xmember to the rocker directly. Also, do you guys with b-bodies and a 4link have to remove the entire package tray, or can I remove the reinforcement that hangs underneath and just trim arount the cage bars. In other words, do the rails clear the upper part of the tray?? Any constuctive criticism is fully welcome as this is my first backhalf build and I am trying to gain as much knowledge as I can. Thanks, and I will post more pics as the progress happens in the next few days. I am slower than most you guys...just taking my time and going real slow. Thanks, Greg.
[Re: Chargerfan68]
#903267
02/08/11 02:33 AM
02/08/11 02:33 AM
I made the plates so they sat on top of the rocker and came down the face of the rocker in an L shape and welded all around. i used 1/8" ( 10Ga ) plate.
[Re: ]
#903268
02/08/11 01:59 PM
02/08/11 01:59 PM
Posts: 642 New Jersey
Craig
New Jersey
The "L" like superfreak said sounds like a great idea. The rulebook doesn't even call for a plate there but its a good idea. I used about a 3x5, 1/8" thick. I welded my plate all around to the rocker metal, but some folks have told me it would have been better to do some 1" stitches instead due to the thin rocker metal. I don't know if that's better but it would be nice to know!
Also, I have that same Alston E-II crossmember, and on mine, I found the driveshaft rubbed the bottom of the loop at some combinations of ride height, 4-link setting, and pinion angle setting. I can work around it, but it seems the loop is mounted higher than it should be. There's not much leeway in setting the crossmember height since it has to match the rockers, but you should mock up your axle height to make sure the driveshaft will clear thru suspension travel. I'll attach a pic of my crossmember being fitted.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: Craig]
#903269
02/08/11 08:17 PM
02/08/11 08:17 PM
Chargerfan68
New York, USA
Thanks for the info and the warning on the loop, Craig. I will mock it up before I weld it in. Another question comes up now: The 4link bracket spacers that you have to cut and weld the brackets together with are CM. The brackets themselves are mild steel, so do they DEFINITELY Have to be Tig welded together. Doesn't make sense to me that the frame and brackets are Mig welded in, and then someone would have to find someone to just weld those spacers in. At least the tubes you can take with you to a shop. I can't tig yet What's your experiences with this?? Greg.
