Page 2 of 4 1 2 3 4
Re: electricity in the radiator [Re: MY340] #903002
01/13/11 11:14 AM
01/13/11 11:14 AM
ill
dennismopar73 Offline
ill
i have thru the years had guys tell
of this,, never seen it
someone would have tp personely
show me this one
so went out and checked every car i have
not a one shows any volts while running or
otherwise!!
i even went to my uncles house and checked out his stuff!!
guess what ???? OOOOO
nada, zelch,
as with mythbusters would say 'debunked'
Re: electricity in the radiator [Re: TrueTripleX] #903003
01/13/11 11:23 AM
01/13/11 11:23 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Just out of curiosity. Which test lead are you probing the liquid in the radiator with? Positive on the battery and negative in the liquid? IMHO if this is the way you are checking, it will show 12v. The liquid is the grounding through the block to the negative side of the battery.
If you are testing with the negative test lead on the battery and the positive in the liquid and get 12v you have issues.
Re: electricity in the radiator [Re: justinp61] #903004
01/13/11 12:46 PM
01/13/11 12:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Water is conductive. That's why you don't bathe with a plugged in hair drier.
- Stu Harmon
Re: electricity in the radiator [Re: feets] #903005
01/13/11 02:07 PM
01/13/11 02:07 PM
Andrewh Online content
Andrewh  Online Content
REGULAR TAP water is conductive.
DI or distiled is not.
Coolant is not conductive either.
But depending on how old it is, it starts to pick up particals and becomes conductive.
So if you flush your system out per maintence standards, then you help to prevent this issue. But it will happen to some degree due to disolved solides. Just makes it worse if you fill your rad from a hose.
Re: electricity in the radiator [Re: Andrewh] #903006
01/13/11 02:58 PM
01/13/11 02:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I know better than to argue with you about water and chemistry. Few people on Moparts have your level of expertise.
H2O has no charge and no desire to swap electrons. The same goes for ethel glycol. However, all the other crap in water is conductive. I'm not sure how many people use distilled water in their radiators.
Mixing tap water with coolant will become conductive easier than a distilled water and glycol mix.
- Stu Harmon
Re: electricity in the radiator [Re: MY340] #903007
01/13/11 05:16 PM
01/13/11 05:16 PM
washington
AB&E Offline
AB&E  Offline
washington
never had this problem myself,maybe cause I drive older junk with bigger problems
but i learned 2 things from this post
1) the anode thing a ma jig goes in the block or rad
2) dont buy any cars from AB&E
especially with #2
Thanks guys dont worry most of you live on the east coast can u say rust 3 times fast by the way the truck I was talking about is still for sale any takers great deal got it from my grandmother
Re: electricity in the radiator [Re: AB&E] #903008
01/13/11 06:54 PM
01/13/11 06:54 PM
scratchnfotraction Offline
shucks..i was just kidding you
I get most of my cars from "sample auto sales BR-549" anyways
Re: electricity in the radiator [Re: scratchnfotraction] #903009
01/13/11 07:28 PM
01/13/11 07:28 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
When I was working in the oil fields in Saudi Arabia we used what where sacrificial cathods to prevent the hot oil flowing through the pipe lines from building up an electrical charge and corrdong the pipelines.
Cathodic protection
Same thing happens in a radiator. I've seen several examples of this in engines, but have never heard how well it works. The Idea behind cathodic protection was to allow the electricity that was building up to go to ground with the sacrificial cathode taking the charge and corroding instead of the oil line. I know we used to stick a penny in the soft top of lead acid batteries and it would corrode intead of the terminals.
Re: electricity in the radiator [Re: Cudajon] #903010
01/13/11 09:00 PM
01/13/11 09:00 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I am in the swimming pool business and we run into something similar. I've only seen it myself on jobs with salt water chlorination or really crappy tap water with lots of metals in it. We use sacrificial anodes to fight it. The ones we use have a bonding lug built in and you are supposed tie that in with the existing pool bonding wire (all pool shells, ladders, rails, and equipment that's metal are connected with a bonding wire)
Re: electricity in the radiator [Re: justinp61] #903011
01/13/11 09:19 PM
01/13/11 09:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Im, sure you dont have 12 volts running through the rad. They must of done the above, one lead to a positive and a ground to the water in the rad. Since your rad and water is grounded , you see 12.xx volts.
There can be electroalisis in rads, but not 12+ volts worth. mike
Re: electricity in the radiator [Re: Sport440] #903012
01/13/11 09:55 PM
01/13/11 09:55 PM
WV
JohnH Offline
JohnH  Offline
WV
I was always told to hang a grounding strap to the ground and let it drag as you drive to disapate the electric to the ground.
Re: electricity in the radiator [Re: JohnH] #903013
01/14/11 12:06 AM
01/14/11 12:06 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I prefer duct tape and an aluminum foil hat.
Re: electricity in the radiator [Re: mcmopars] #903014
01/14/11 09:00 AM
01/14/11 09:00 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
wow, been around cars for 35 years and never heard or should i say has never happened to me or seen it,but to each his own.learn something new everyday
45 years here. Never heard of such a thing. But people buy ShamWows, too.
Re: electricity in the radiator [Re: TrueTripleX] #903015
01/14/11 09:15 AM
01/14/11 09:15 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
If you system is creating 12V, you have a new perpetual motion machine and free electricity. Start you car, run an inverter off it and power your electronics simply from the corrosion in your system.
A galvanic reaction is in the mV, not volts. I am not denying you have a problem, but I think the magnitude is wrong. I have never heard of this and I been messing with cars 30 years. I am a shade tree mechanic, not an expert, but I am a professional electrical engineer. You need to watch how the snake oil salesman is presenting the snake oil. Make sure he did not take the "oil" out of a rain barrel.......
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: electricity in the radiator [Re: Commando1] #903016
01/14/11 01:20 PM
01/14/11 01:20 PM
ill
ill
ok guys antifreeze will change over time and become corrisive, cyle of heat /cold and age
thats why you are supposed to change youre fluid every 2 years or when ever ,
water does conduct elec ,
if you have 12 volts running thru you radiator ,,
FIX YOURE PROBLEM,
COLLANT DOESNT GENERATE ELECTRICITY!!
alluminum radiators , alluminim heads require , attention as to corosive types of antifreeze, and proper ph balance
as with desil motors same deal
it would be very usefull to use distilled water as it has little to no impuritys to break the antifreeze down you are using quicker,
Re: electricity in the radiator [Re: dennismopar73] #903017
01/14/11 01:32 PM
01/14/11 01:32 PM
PURE water, DI water, distilled water DO NOT CONDUCT electricity.
New coolant out of a jug also does not conduct.
FIX YOURE PROBLEM,
Re: electricity in the radiator [Re: JohnH] #903018
01/14/11 07:23 PM
01/14/11 07:23 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I know alot of the old timers used to have those rubber/metal straps hanging down from their vehicles.. .I have'nt seen anyone do that with computor controlled vehicles....
Re: electricity in the radiator [Re: screamindriver] #903019
01/14/11 08:49 PM
01/14/11 08:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Those straps were to kill static electricy caused by the old style tires. They had more carbon in the rubber and that caused a lot of static charge that would zap you when you touched the door handle.
Re: electricity in the radiator [Re: stumpy] #903020
01/14/11 09:05 PM
01/14/11 09:05 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
And sliding corderoy pants across vinyl seats also, Zap!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: electricity in the radiator [Re: GO_Fish] #903021
01/14/11 10:49 PM
01/14/11 10:49 PM
I just saw a 05-09 chebby truck with a rubber strip draging the ground tied to the hitch with a gronding bolt/washer deal and thought about that comment on this post
so yes i have seen it on newer trucks..only 1 but I thinking thats wat it was anyways
i know I used to have a 12 volt shock deal rigged up for dogs peeing on the rims and drug a ground strap for it
get out of the truck and flip a switch...zap the crap right out of them while peeing
dont take long to break them thats for sure
Page 2 of 4 1 2 3 4
