Re: electricity in the radiator
[Re: Yancy Derringer]
#902984
01/12/11 06:37 PM
01/12/11 06:37 PM
Posts: 1,061 Ball Ground GA
TrueTripleX
Ball Ground GA
I don't know if he's right or not but he could be. Electrolysis works more like a battery, remember your simple science?
You need two "dissimilar" metals and an electrolyte.
a lemon, a dime, and a penny make a battery. It might just be that the radiator, the block, and the antifreeze are causing this. It's been a long time, but big trucks used to use sacrificial filters and additives to help prevent this, and if it's this bad, Chrysler should be doing something with it.
Thanks Yancy and I do remember the high school science, but this is registering 12 V. It seems like this is too high a number. They also stuck the probe in the upper radiator hose (in the middle) and registered 12V. Strange???
[Re: Andrewh]
#902995
01/12/11 09:07 PM
01/12/11 09:07 PM
Posts: 4,179 California
mickm
California
it isn't a bandaid, it is how it works.
i guess i don't understand why this isn't an issue with every car then. it sounds like this exists to some degree in every car, but more so in others, enough to cause this type of damage.
so wouldn't there be some reason why his car has a higher amount of electricity flowing through the coolant, and try to figure out why that is?
[Re: TrueTripleX]
#902996
01/12/11 09:11 PM
01/12/11 09:11 PM
Posts: 53 Jensen Beach, Florida
pressureangle
Some years back I serviced a fleet of Caterpillar forklifts which constantly threw trouble codes and ate sensors, brass plugs and even the thermostats. To make a long story short;
First check for *AC* voltage in the coolant. If you have any (~5vac) have your alternator tested by a competent auto electric shop (not the NAPA spin-o-tron) Secondly, as others have said be certain that the radiator, chassis, and engine are all thoroughly grounded together. I prefer to ground the chassis and radiator both to the same attachment point as the engine block negative. If your engine and radiator are completely grounded together, there won't be any juice to pass through the coolant.
Lastly, and importantly; what we discovered with the Caterpillar forklifts was that the alternator bodies were not grounded to the engines. The blocks and brackets were painted, and although the engine and radiator were both grounded to the frame, the ground loop found its way back to the alternator through the engine(starter ground)chassis(lights/gauges grounds)via the coolant. I still don't fully understand the path, but we grounded the alternators thoroughly and the problem went away.
Why do I torture myself so?
[Re: scratchnfotraction]
#902998
01/12/11 11:04 PM
01/12/11 11:04 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Old coolant can become corrosive itself also, pH becomes acidic. More of a problem with diesels than gas I think, and more of a problem with aluminum radiators than copper. In general the more aluminum parts in the engine, the more vulnerable also I'd say. Stay up on your coolant changes and use the grounds mentioned. Would be nice if someone made a radiator cap with a zinc anode hanging from it... At some point, corrosion becomes rampant and takes on a life of its own in the entire system or vehicle. Once the corrosion has become that entrenched, there is almost nothing you can do to stop the process more than briefly. You put new parts on and they corrode within months. When it gets to that point, time to look for another ride.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#903000
01/12/11 11:53 PM
01/12/11 11:53 PM
Posts: 204 washington
AB&E
washington
my point exactly time for a new ride there is a level of elec. in most i believe but then there is to many amps or what have ya very common in big diesel trucks atleast the ones the built 30 yrs ago
