Re: electricity in the radiator
[Re: MY340]
#903002
01/13/11 11:14 AM
01/13/11 11:14 AM
Posts: 2,177 ill
dennismopar73
ill
i have thru the years had guys tell of this,, never seen it someone would have tp personely show me this one so went out and checked every car i have not a one shows any volts while running or otherwise!! i even went to my uncles house and checked out his stuff!! guess what ???? OOOOO nada, zelch, as with mythbusters would say 'debunked'
[Re: justinp61]
#903004
01/13/11 12:46 PM
01/13/11 12:46 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Water is conductive. That's why you don't bathe with a plugged in hair drier.
[Re: Andrewh]
#903006
01/13/11 02:58 PM
01/13/11 02:58 PM
feets
Senior Management
Senior Management
Irving, TX
I know better than to argue with you about water and chemistry. Few people on Moparts have your level of expertise. H2O has no charge and no desire to swap electrons. The same goes for ethel glycol. However, all the other crap in water is conductive. I'm not sure how many people use distilled water in their radiators.
Mixing tap water with coolant will become conductive easier than a distilled water and glycol mix.
[Re: MY340]
#903007
01/13/11 05:16 PM
01/13/11 05:16 PM
Posts: 204 washington
AB&E
washington
never had this problem myself,maybe cause I drive older junk with bigger problems
but i learned 2 things from this post
1) the anode thing a ma jig goes in the block or rad
2) dont buy any cars from AB&E
especially with #2
Thanks guys dont worry most of you live on the east coast can u say rust 3 times fast by the way the truck I was talking about is still for sale any takers great deal got it from my grandmother
[Re: scratchnfotraction]
#903009
01/13/11 07:28 PM
01/13/11 07:28 PM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
When I was working in the oil fields in Saudi Arabia we used what where sacrificial cathods to prevent the hot oil flowing through the pipe lines from building up an electrical charge and corrdong the pipelines. Cathodic protection Same thing happens in a radiator. I've seen several examples of this in engines, but have never heard how well it works. The Idea behind cathodic protection was to allow the electricity that was building up to go to ground with the sacrificial cathode taking the charge and corroding instead of the oil line. I know we used to stick a penny in the soft top of lead acid batteries and it would corrode intead of the terminals.
[Re: justinp61]
#903011
01/13/11 09:19 PM
01/13/11 09:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Just out of curiosity. Which test lead are you probing the liquid in the radiator with? Positive on the battery and negative in the liquid? IMHO if this is the way you are checking, it will show 12v. The liquid is the grounding through the block to the negative side of the battery.
If you are testing with the negative test lead on the battery and the positive in the liquid and get 12v you have issues.
Im, sure you dont have 12 volts running through the rad. They must of done the above, one lead to a positive and a ground to the water in the rad. Since your rad and water is grounded , you see 12.xx volts.
There can be electroalisis in rads, but not 12+ volts worth. mike
[Re: mcmopars]
#903014
01/14/11 09:00 AM
01/14/11 09:00 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
wow, been around cars for 35 years and never heard or should i say has never happened to me or seen it,but to each his own.learn something new everyday
45 years here. Never heard of such a thing. But people buy ShamWows, too.
[Re: TrueTripleX]
#903015
01/14/11 09:15 AM
01/14/11 09:15 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
If you system is creating 12V, you have a new perpetual motion machine and free electricity. Start you car, run an inverter off it and power your electronics simply from the corrosion in your system.
A galvanic reaction is in the mV, not volts. I am not denying you have a problem, but I think the magnitude is wrong. I have never heard of this and I been messing with cars 30 years. I am a shade tree mechanic, not an expert, but I am a professional electrical engineer. You need to watch how the snake oil salesman is presenting the snake oil. Make sure he did not take the "oil" out of a rain barrel.......
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: Commando1]
#903016
01/14/11 01:20 PM
01/14/11 01:20 PM
Posts: 2,177 ill
dennismopar73
ill
ok guys antifreeze will change over time and become corrisive, cyle of heat /cold and age thats why you are supposed to change youre fluid every 2 years or when ever , water does conduct elec , if you have 12 volts running thru you radiator ,, FIX YOURE PROBLEM, COLLANT DOESNT GENERATE ELECTRICITY!! alluminum radiators , alluminim heads require , attention as to corosive types of antifreeze, and proper ph balance as with desil motors same deal it would be very usefull to use distilled water as it has little to no impuritys to break the antifreeze down you are using quicker,
[Re: dennismopar73]
#903017
01/14/11 01:32 PM
01/14/11 01:32 PM
Andrewh
PURE water, DI water, distilled water DO NOT CONDUCT electricity. New coolant out of a jug also does not conduct. Quote:
[Re: JohnH]
#903018
01/14/11 07:23 PM
01/14/11 07:23 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I was always told to hang a grounding strap to the ground and let it drag as you drive to disapate the electric to the ground.
I know alot of the old timers used to have those rubber/metal straps hanging down from their vehicles.. .I have'nt seen anyone do that with computor controlled vehicles....
[Re: GO_Fish]
#903021
01/14/11 10:49 PM
01/14/11 10:49 PM
Posts: 15,487 Florida
scratchnfotraction
I just saw a 05-09 chebby truck with a rubber strip draging the ground tied to the hitch with a gronding bolt/washer deal and thought about that comment on this post so yes i have seen it on newer trucks..only 1 but I thinking thats wat it was anyways i know I used to have a 12 volt shock deal rigged up for dogs peeing on the rims and drug a ground strap for it get out of the truck and flip a switch...zap the crap right out of them while peeing dont take long to break them thats for sure
