Narrowing Dana 60
#902043
01/11/11 02:11 PM
01/11/11 02:11 PM
Posts: 4,597 Motor City
6PKRTSE
Motor City
Anyone have any picture or narrow your own Dana or 8-3/4? I am getting ready to narrow mine for my Challenger. I have the new ends & new spring perches. What did you guys do for a fixture to hold everything true & centered. Just looking for idea's. I think I know how I am going to do it. Another idea or two never hurts.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Narrowing Dana 60
[Re: PLUM BAD]
#902048
01/12/11 12:25 AM
01/12/11 12:25 AM
Posts: 43,394 Bend,OR USA
Cab_Burge
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02029.jpg)
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02027.jpg)
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02016.jpg)
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02017.jpg)
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02015.jpg)
![](http://i173.photobucket.com/albums/w43/PLUM1320/DSC02026.jpg)
Have you check that rear end for square off of the new bearing flanges yet? If not you probally should I had my Dana 60 narrowed buy a shop that uses those, it is 1/2 inch narrower in the front 30 inches out and similar differences top to bottom I called the shop and they siad to take it to Dutchmens in Portland and have them straighten it out Another local shop that uses those also said he has to straighten every rear end he does(narrows), Ford, Chevy, Mopars, Dana or any other ones he does I have Ford nine inch (don't tell Quicktree )that is going into my 1940 Ford street rod that needs narrowing, I will take it and the Dana 60 to Dutchmen to do, narrow and straighten the nine inch and straighten the Dana 60 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#902049
01/12/11 12:48 AM
01/12/11 12:48 AM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
How can the flanges NOT be square and true...that is what that fixture is for?? Every narrowing shop that I know of uses that type of fixture. If it is a quality narrowing tool and checked for damage before using, I would think the rear would be straight and true.
Just commenting and asking.
Greg.
[Re: Chargerfan68]
#902050
01/12/11 01:43 AM
01/12/11 01:43 AM
Posts: 289 So. IL. USA
PLUM BAD
So. IL. USA
Greg.
Thanks I was woundering the same thing. I used 1 3/8 in. solid and true shaft that was longer than the rearend so both sides are jigged at the same time off of the carrier bearing saddles. I could spin the shaft after the ends cooled off. If it weren't true, I doubt that the shaft would spin. It would be in a bind.
[Re: PLUM BAD]
#902052
01/12/11 01:53 AM
01/12/11 01:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I made up pucks just like yours and I also use a long straight edge to measure out at about 20" front and rear then turn them for up and down just to make sure and the diffs I have done are fine... I even check them off the axle flange 20" out in both directions just to be sure ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 6PKRTSE]
#902054
01/12/11 11:25 AM
01/12/11 11:25 AM
Posts: 3,880 Smyrna, South Carolina
STEFF
I can do it for you. I have the mandrels & fixture shaft. PM me if interested.
[Re: Cab_Burge]
#902056
01/12/11 07:34 PM
01/12/11 07:34 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Who cares if the bearing flanges are square?
I care, I like my tires to be square with the rear end, not toed in or out That makes it a little easeir to make the car go straight down the track when the front wheels are in the air Little things can mean a lot
I don't know about your rear end but on the one I have all the bearing flanges do is hold the brake backing plate on. ![](/ubbthreads/images/graemlins/thumbs.gif) Now ,the bearing bore must be square and true ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: The Shadow]
#902057
01/12/11 09:01 PM
01/12/11 09:01 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Ok, just holds the brake hardware on... If the flange is perpendicular to the bore,the flange will be in spec. if not, caliper not in same plane as brake disc... = wear and tear. Drum somewhat forgiving but.... Some forgiveness in bore center alignment but good indicator of that is flange runout. Flange runout can very some also from warpage during welding, not likely but potential.
[Re: theclutcher]
#902058
01/12/11 09:31 PM
01/12/11 09:31 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
If I got my math right, 1/4" (1/2 of the observed measurement) out 30" out is less than 1/2 degree. sin of that angle is .0083330444544. The sin value for a 1* angle is .0174. So the total out is less than 1* if at 1/2", 30" out. Nothing like a little trig for a Wed afternoon... Some Old Hippie, Caught Another Hippie, Tripping On Acid ![](/ubbthreads/images/graemlins/laugh2.gif)
